Up for sale I have a full set of splitfire coils to suit 32/33 gtr, also to come with it is a 6 puk moristech ignition module that replaces the standard rb26 igniter, coils are less then 2500kms old, all in perfect working order, with the igniter the setup held well for 600kw
Will get pictures up in next couple days, ignition module cost $380 itself, selling as I've gone a different setup so priced cheap to sell
Will post at buyers expense
$550
4 hours ago, GH05T said:
how much for just the coipacks?
Pm sent GHO5T
I'll take the ignition module if Ghost wants the coil packs - $100
Need a pic please...
Edited by TMLP
added info
  • 3 weeks later...
