2015 WRX STI
12 months rego
$39000
34000km
Pulse "Stage 3+" kit
All work by Pulse Racing in Menai
ECUTEK
Invidia TBE
Process West TMIC
Process West CAI
550hp fuel pump
White Line F & R sway bars
Grimspeed AOS
GFB Respons BOV
Mishimoto oil cooler with thermostat
Enkei RS05RR 9.5 x 18 + 40.
New 245/35 18 Pirrellis
Front and rear crash cameras
Alarm
Rhino roof racks
Window rain guards
Other bits and peices
No swaps (unless you have a low km NB series 4 SE ?hard top? which could be part payment, maybe)
No "test drives" unless you can flash the cash
Email me on: [email protected] to organise an inspection, the inspection will be in Holsworthy
Im in no real rush to sell so don't bother low balling as I will not reply, this is a fair price, look at every other one, then look at this
Alot of SAUNSW members will know me and how I look after my cars
Car has been my daily driver
Mature owner, well I'm 52, actual maturity may vary
Modified so when I'm driving the car sounds the boss and I can think I am Colin McRae on the special stage of "going for a drive".
  • Like 2
https://www.sau.com.au/forums/topic/473325-2015-wrx-sti/
Also comes with a Torx t70 socket for draining the gearbox, all drivetrain oils, front diff/gearbox and rear diff were changed at 15k km using Penrite full synth.
Engine oil, Nulon full synth 0W40, and filter changed every 5k km.
Brake fluid had 2 full flushes, one at 5k km, the other at 20k km.
Full lip kit.
Car cover.
The Blackvue duel cameras also have a battery saver wired it, all professionally installed.
If you have a shop where you want it inspected on a hoist I can go for that as long as its not to far away and work permits, Pulse Racing and GEM are close to me, all at your cost of course.
https://www.sau.com.au/forums/topic/473325-2015-wrx-sti/#findComment-7868923
Thanks guys, I built it to be fun and reliable.
I'm after something else to play with now as the kids have just got their licences I don't need 4 doors and 5 seats, plus as the car is restricted the kids cannot taxi me around after I have had a beverage or two.
I need something fun but also p plate friendly, hence the MX5, "again".
https://www.sau.com.au/forums/topic/473325-2015-wrx-sti/#findComment-7870114
$38,500.
Best value for money VA STI on the market.
Coming up to 35k km, so, It's getting engine oil and filter done this week. More Nulon 0w40 goodness.
https://www.sau.com.au/forums/topic/473325-2015-wrx-sti/#findComment-7870447
$38,000 firm
Seems like no one is looking for one, the cars on the for sale web sites don't seem to be moving to quick either, even though mine is in better condition, has all the good bits and is priced more competitively for a quick sale.
The car has had over 10k$ in quality mods.
Stock STI's aren't that impressive, but once you free up the inlet and exhaust, give the rubbish OEM tune a tweek, they really wake up.
As for the tune, I told Paul from Pulse Racing to give it all the good bits, but to ensure the car is 100% reliable as a daily, it's making just over 200kwatw which he said was the happy place for longevity, the also recommend and supplied all parts, except for the GFB BOV, that was all me, the BOV is the respons type, so it's manually ajustable from closed all the way to full VTA for hectic Pttsssss goodness for when I'm feeling silly, currently set at about 30% VTA, so it's only slightly hectic at the moment.
If it doesn't sell for 38k I'm keeping it and buying a beater so the kids can be my personal Uber.
Thanks for the comments.
https://www.sau.com.au/forums/topic/473325-2015-wrx-sti/#findComment-7870704
2 hours ago, mlr said:
Yeah nah. Been there, done that.
:7_sweat_smile: worth a shot lol..
I'm over mine but don't want to sell it for peanuts to little nubs on facebook.
https://www.sau.com.au/forums/topic/473325-2015-wrx-sti/#findComment-7871368
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
    • Finally back on the ground and once around the block for the first time in 2+ years
    • Ok a solution was found. I had left the factory oil temp sensor in and it was hooked up. My car never had the triple gauges.  Apparently when you delete the factory pressure and leave the temp sensor connected it triggers the oil light on the dashboard. Disconnected the temp sender, no more light.  I still haven't gotten around to look at the diagrams to figure out how/why they are tied together.
