Hi all, i just tried to redo the whole interior and bought all new parts, after finish installing, i found out the ash tray's color dont match the center console at all, did i order the ash tray wrong or did nissan has hard time color match their interior?  please help.......i have bought 2 ash trays and both don't match at all
the part # i order for first ash tray:
68800-ab100
pics:  you can see the color is in darker shade
Then i ordered a second ash tray, with part #
68800-aa005
and found out it's black color!!!!
so anyone knows what is the correct part # for ash tray i should order which will match the color of center console??
thanks
I believe the 2 ash trays you ordered were;
- dark brushed look silver is from a Series II R34 GTR - 00(MY01)-02
- the black ashtray is from a Series I R34 GT-t
The astray you need is the Series I 99-00(MY00) astray which is a light gold color
  • Like 1
so do you know what is the part # for it please?
thx
If you want to confirm which gear surround you have, remove the screw behind the ashtray, then lift the gear surround up to unclip it and lift it out. Part number is moulded on the back I’m pretty sure, S1 is 96935-AA410, S2 is 96935-AB110.
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
