Hey guys I have a 95 GTS25T which is about to go in for a Cambelt replacement. I bought a kit online without checking the parts first (I know silly) but it came with a Mitsuboshi timing belt, GMB tensioner and idler, and a Seiken water pump. I know these parts are probably the cheapest available to fit but will they be ok? Its running standard boost, no intercooler or anything mods are just exhaust, adjusties and pod filter and a few other small things. I also dont plan on drifting every single corner >:) just a few when its wet. Please any help as to how long these parts would compare to a standard Nissan belt?
Thanks
https://www.sau.com.au/forums/topic/473705-rb25det-cambelt-question/
most of those parts might be ok but the water pump...personally i would only ever go genuine nissan as i purchased a 'protex' pump and it only lasted 25,000kms [emoji22][emoji22] never again will i skimp on parts. What you think you save on cheap parts will potentially cost you a lot more in the long run.
