Its finally time to sell my pride and joy,
1994 R32 GTR
127,865ks
$49000
the car has always been garaged and only ever ran on 98 it's just had a fresh rebuild only 800ks ago and was fully resprayed 3 years ago but now I've started a little family I dont have the time or money to fully enjoy this beautiful car to its fullest nor do i have the space to keep it as an investment,
Mods
Engine Block:
- freshly checked and tested R33 block
(800ks ago)
- Forged pistons
- STD Rods
- ACL race bearings
- ARP 2000 Head studs
- GT 2860-5 turbos
- HKS dumps and front pipe
Head work:
- Tomei 264 cam shafts
- Tomei Cam Gears
- Heavy duty valve springs
Efi:
- SARD intake fuel pump
- SARD Fuel rail + Fuel pressure Reg
- SARD 700cc Fuel Injectors
- Haltec Platnium Pro ECU
Intake/Cooling:
- 110mm thick intercooler
- HKS intercooler Hard pipe kit
- Twin Mines pods
- Aluminium radiator
- Oil relocation kit
Drivetrain/Suspension:
- Front and rear LSD
- BC coilovers
- Nismo Super Copper Mix clutch
  (800ks old)
Interior/Exterior
- Haltech Platnium pro ECU
- Turbo E-Boost in cabin controller
- Trust side skirts and rear pods
I really do love this car and it brings a smile to my face every time i even just sit in it, it is a regrettable sale but it's time for a new family car, no time wasters tyre kickers or test pilots, if I miss your call or it goes straight to voice mail just shoot me a text and I'll call you back, (my job site has horrible reception)IMG_0087.JPG.66cbe94ab07858a4df8445185237481a.JPGIMG_0088.JPG.5bcb455ca2e5e599bb795610f2ac7f0c.JPG313860927_RTRSAUdynoday1.jpg.4620965f51b42b2a157be25fad52396b.jpg1147159537_RTRSAUdynoday3.jpg.cc5d89848ae79d765b211dfc71f0b074.jpg641909034_RTRSAUdynoday4.jpg.fdab5eb39fa88b835ed4c46368baffb5.jpg2099763610_RTRSAUdynoday6.jpg.5c3f83359c8303b50855715c6d3378b4.jpg645737061_RTRSAUdynoday7.jpg.2becfa3ace2b57d8c22c4bce37ddcc40.jpg1096911778_sns2.jpg.c907118881fef8e89b12af30a3cd677e.jpg2051121891_sns3.jpg.9548cef0186e1e0231221fe67b71bfcd.jpg20180516_161735.thumb.jpg.7f36fe0152538f172b2a5fe79a293298.jpg1717157243_P1010169-Copy.JPG.90bcc1aeee3faac277a6b634794a5c62.JPGP1010170.thumb.JPG.f3ec39ef7ecf37c27e945d924a8169ca.JPGP1010177.thumb.JPG.26092996b26c790d0709e2890d7cab1c.JPGP1010180.thumb.JPG.d1281f30b624940d93a6848b25f07f91.JPG
Sam 0406662005
  • Like 1
https://www.sau.com.au/forums/topic/474109-fs-1994-r32-gtr/
  • 1 month later...
  • 2 months later...
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
