Hey there fellas. I currently own a 180sx fitted with a Greddy Profec A EBC. Immediately after fitting a boost gauge (now a while back), I saw that the needle regularly reached 16psi. This was quite alarming as the EBC was only set to 7psi (stock). After I noticed this, I verified that the boost gauge was working properly and was not faulty, by verifying that the EBC readout also reached 1.0 bar (14psi or thereabouts) as well.
First question; why is the car not holding boost around 7psi as it should? I have a feeling that either the solenoid or the actuator is stuffed. Are these problems common or unheard of? Which brings me to a third question; if the actuator needs to be replaced, is it possible to purchase and fit an actuator separately? Or do I need to replace the whole turbo assembly?
I'm starting to get a bit freaked out that my turbo or engine is going to suddenly explode, so your help is greatly appreciated.
https://www.sau.com.au/forums/topic/47428-overboosting-car-not-holding-boost/
Noticed a similar thing with my 34. It has a Greddy Profec EBC and hand controller(hand controller not hooked up though). The boost is set to around 13-14 psi at max but i regularly see it hit 16psi with the very cold mornings we experience here in Canberra.
I thought an EBC was not supposed to allow this to happen?
Make sure you have completely removed the factory solenoid...
Make sure the EBC is connected properly, and there isnt any leaks.
If so, it should hold boost fine, ive got an avcr, and the worst it ever spikes is 1 psi
:werd: sounds like the solenoid isnt set up right. 2psi spike? damn, the worst my hks evc spikes is 0.02bar (0.3psi)
Everything is set up right, no leaks in hoses and the factory solenoid has been removed completely. The boost is spiking to more than double what it is set to, this is what's scaring me. If it was only 0.1 bar or 1 to 2 psi it would be OK but double the boost says something is definitely wrong.
The only other option I can think of at the moment is to purchase or lease another profec A solenoid to see whether that works or not.
YOYO
It could be that your gain,set gain and set boost are set to high.If these are to high then you will run into overboosting problems.
I dont know how different the profec A is but it should be simpiler to tune.I use a Profec b spec 2 ebc and it was spiking also.
Run it turned off with the controller hooked up and see if the car does the same.
And also try to keep your hose length to a minimum.Have the boost controller located in a cool area of the engine bay not right next to the motor.
Remember start at zero and work your way up.
Trust33 -> I'll have to check those knobs you mentioned. What do the ratio/time/offset knobs actually do? I have these three little knobs to the right of the main boost setting but haven't touched them since purchasing the car.
BTW, I've already tried turning the controller off and it still overboosts, so it's not the EBC's fault.
Low25 -> Yes, the profec A does have an OverTake Boost (O.T.B) button but i don't know how much it increases boost by, it lasts around 10 secs though.
The solenoid wants to reach the set boost but it cant cause uve set it to high. Couple that with a small ass exhaust housing and wastegate that cant handle the exhaust gas flow from the engine and the solenoid wants it to achive all this when it cant cause its SET TO HIGH SO BRING IT BACK TO ZERO.
The unit only reads what you set it to.
Trust33 -> Umm, I've only set it to stock, can't get any lower. I've also tried setting the boost to zero but that didn't work either, the car still overboosts.
rb25 -> I've checked all lines and they are all ok, the controller came as is, installed with the car.
I have a feeling it could be on a different high boost setting, I'm going to check this out tomorrow.
Id suggest that you get a users manual from somewhere.
If you cant find your problem,then you should assume that its your solenoid.
Here you go i may be able to help you.heres a link to a blokes site where he has installed a profec a on his rotary.The diagram shows the points at which the boost controller should be connected.And it is for an internaly actuated wastegate like the one youve got.
http://www.scuderiaciriani.com/rx7/profec_install.html
This is the main page (appendix) to it.
http://64.233.167.104/search?q=cache:cbHl-...df+format&hl=en
This one also has the power fc,avcr and a heap of other manuals and wiring diagrams for peeps to download.
YOYO;
I currently run a Profec A ebc on my r33, have u done the learning mode so that the ebc can learn ur turbo cruve, i was lucky and bought mine off someone how had it on a r33 so it was already set to a stock turbo, so i get no overboosting.
Try to do the learning mode or get it tune by a workshop
I got the manual checked out the settings. Low boost is 5bar and high is 7bar.
Today I took it for a good fang and got the car up to 18psi in 5th!!! Needless to say, I let go of the accelerator pretty quick after that!
13_devil -> how did you get the EBC into learning mode? I've got the downloaded manual, but it doesn't say how.
Well guys got it fixed yesterday (Thanks Faeez, you're a f**king legend!). We played around with the hoses a bit and checked that the actuator opened up the wastegate using a bicycle pump. As it turns out, the piping coming off the intercooler charge pipe to the solenoid had an air filter that was leaking.
Now that it's fixed, the car feels a LOT slower; 7psi is nothing compared to 18!!! Oh, and I don't have an excuse to upgrade my turbo :rofl:
Anyways, thanks for your suggestions ppl.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
