Hey guys, i have a 92 GTSt Type M that ive been having some starting issues and after some talking between myself a another mechanic we came to the thought that it may have a stuck open purge valve, alas information is short in english. So why might i have raw gas in this line here?
Its not a lot of gas but enough to be of concern, especially since its infront of the throttlebody?
https://www.sau.com.au/forums/topic/474361-gas-in-strange-places/
That hose supplies air from upstream the throttlebody to the idle control valve at the back of the plenum chamber.  If by "raw gas" you mean petrol, then.....WTF?!  There really shouldn't be any liquid petrol just rolling around in the plenum chamber, let alone finding its way back through the ICV and into that hose.
By purge valve, are you talking about the fuel tank breather system?  If so, there should never be liquid fuel in that either, just vapour.  It would have to be dead cold for fuel vapour to recondense in there.
Well therein lies my problem haha. It was definitely petrol and there was maybe a half teaspoon of petrol in the line.
Ok after digging through every article i could find,  i found out the line is run to the IACV and an air regulator valve. So there shouldnt be fuel in the line, however there is a small vacuum line that runs to the rear fuel pressure regulator.
So i think the rear FPR might be going bad and pumping fuel into the lines off the IACV and air regulator
  • 2 months later...
Not sure if anyone was following this but i removed the fuel pressure damper and replaced it with a fuel pressure regulator adaptor and 90° brass fitting and the car now runs 100% again.
The damper ended up having a ton of fuel in the vacuum line and on the wrong side of the diaphragm.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
