Guys;
I've read the threads on here regarding sump baffles, SBS and the RB26 engine. My engine maunual shows that the RB26 already has baffles installed in the sump.
At the excuse of showing my ignorance, what is it about the standard ones that makes them unsuitable for track work. Is it a lack of anti surge baffling?
Std baffle is more a windage tray which attempts to separate the crank from the sump oil.
There are no swing gates or any sort of surround around the pickup and the oil can freely slosh from side to side under cornering/braking/accelerating.
Aftermarket baffles have the gates/surround but do not increase oil capacity.
A trust sump extension or Performance metalcraft sump is reqd to do that.
Run a GTR more than 1/2L low on oil at a track day at your own risk and if you are a good steerer on race spec tyres even a full sump wont help...
Cheers
Ken
Yeah... NRB said he was talking to Ben and he claimed that most oil starvation problems were because of poor oil choice... I asked NRB to elaborate, but he didn't :(
http://www.skylinesaustralia.com/forums/sh...99&postcount=86
Merli,
Wasn't there recently a thread, about sump baffles and Ben from Racepace (can't recall exactly the quote) but mentioned baffles aren't neccessary, it's all about the oil you use on a track??
WTF??
I don't think so.
Watch the oil pressure gauge( decent aftermarket one) on a GTR through the long sweeper at barbagallo and tell me its not oil starvation...
cheers
ken
would over filling the engine help? e.g putting in an extra 2 or 3 liters?
steve
Yes... overfilling a litre or two will help, but it's only a band-aid solution, and you STILL risk oil starvation. Is it worth the risk? RB26DETTs aren't cheap to rebuild or replace :Oops:
Yeah... NRB said he was talking to Ben and he claimed that most oil starvation problems were because of poor oil choice... I asked NRB to elaborate, but he didn't :rofl:
Sorry Merli, I thought I did... Ben told me that there's quite a few guys running very fast times with standard sumps that haven't run into problems. He also said to me that a lot of blokes were running oil with too low a viscosity - oils with the viscosity of water being a big problem causing the spun bearings...
Ben didn't say it was overkill to replace the sump etc, all I stated was that he said a lot of failures were due to poor oil choice. Again sorry about any confusion.
Cheers Nick...
So we should be using a thicker oil then? Wouldn't that have the follow-on effect of slowing oil flow and perhaps limiting oil flow back down into the sump? :confused: So obviously there's too thin, and too thick. What's the "happy medium"? :)
I'm using Castrol Forumla R 10W60... It's what CRD uses in all their big RB26 engines...
What does Ben recommend?
I have just gone through the whole experience of spinning a bearing at a track day after 5 laps. Before the track day I put brand new Castrol R oil (and filter) and filled it to the high point. I would not recommend using a GTR on the track without a sump baffle installed. I had one custom made that adds another 2.5l of capacity and has proper baffling that has trap doors to stop oil surge. I will gladly post picks if anyone is interested?
Also going to place the restrictor in the block and running an external oil return line as per Sydneykids suggestion. I do not want the same thing happening again next time I am on the track.
Just a couple of informative links on lubrication, adding to the discussion on thicker oil use.
http://www.syntheticwarehouse.com/lubricat...%20concepts.htm
http://www.lubricatingoildepot.com/engine-oil.html
http://www.infodotinc.com/engine3/en32-37.htm
So the key is not too thick and not too thin. Still determining the best result.
Ken has a good point, but watching the oil guage through a fast sweeper??????
Note I said a fast acting gauge, which the factory one most definetely isn't ! :)
I use a Greddy peak/recall with reset for low oil and this brings the light on.
I have had the gauge drop to 1kg/cm thingy type number and the factory gauge is still showing 4 kg whatever they ares...
Cheers
ken
Nice Ken. Would be interesting data to log at high resolution.
1kg/cm^2 is about 1 bar or 14.22 psi, which is a pathetic amount of pressure, but in a dynamic fluid bearing it is not the delivery pressure that provides the actual lubrication but the viscosity of the oil, so if zero pressure where there (meaning air pickup) the bearing would run dry, meaning metal on metal and probable death. Any measurable pressure means the bearing is lubricated. A higher viscosity oil would result in an almost immeasurable drop in power, but would need less oil flow volume for the same lubrication task and greater resistance to inertial surging. Temperatires in the oil may increase so a cooler would be advisable. Nothing comes free.
Still looking for the perfect multigrade oil spec though.
I'm also using Castrol Formula R Synth 10w60...
i added an extra litre in before the track day i went to at winton.. didn't have any problems while i was there... but im running on road tyres, not semi comp
but snowman on the other hand has standard sump baffle, runs semi comps and has done heaps of track days with no problems yet?
But apparently thats because I'm a naive dickhead and work on the theory of what I don't know can't hurt me.
So if anyone else needs some advice on how to turn a blind eye to a potential disaster because they either cbf or can't afford to fix it then come talk to me. This is my area of expertise.
Cheers Nick...
No problem Andrew. Ben recommended 10W60 just like you're using. I like Castrol Formula R syth myself... pity it doesn't smell like the old Historic Formula R mineral oil I run in the Mini; beautiful smell. :Oops:
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
