Hi guys
I got a issue with my R34 GT-Turbo 1998, Semi Automatic for Months now but manged..
Regardless when the car is cold or warmed up, when I shift into Reverse or Drive.. the rpm drops and will stall. It starts back up again perfectly fine.
Now the only way I can manage to bypass this is to give it a little gas right after I shift into gear so the revs won't drop and stall out on me.
And also when I come to a full stop at a red light for example, the car revs would drop and sometimes stall too.  The only way I can stop this is manually use the TipTronic and shift it into Gear 1 before I fully get to a Stop and it won't stall out.
I forgot to mention most importantly that the A/T light flashes before I start the car up. it flashes 16 times.
Now it also gets WORSE, lets say I attempted to "Drift" which I never have even done, but lets say I wanted to, for example. When I get to a Roundabout and start turning while giving abit of gas, the revs somehow holds back and the A/T light then comes on after I turn and the car will start going into LIMP Mode. So I would have to shut it off and start the car back up again and it runs fine and the A/T light is gone. The only way I can bypass this that when I get to a corner or a sharp turn.., I can't accelerate while turning at the same time all else the A/t Light comes back on, As I straighten the wheel back straight the Revs pick up again as if the car didn't allow me to go fast on a corner... I can't even have a joy ride anymore :( My power Steering fluid is full too so hmmm
Now I just got my Throttle Position Sensor changed and cleaned the Throttle, I have also checked for any vacuum leaks carefully but nothing. I changed my Coil packs/spark plugs recently too, Cleaned my O2 Sensor, Cleaned the Air flow meter and checked for any leaks, cleaned the Idler Air Valve, Checked my Automatic fluid and its nice and red and on Full (also got it serviced for new transmission filter and fluid changed) tried a lot but still no good :(
Now I can only think of Solenoids A & B or some sort of Sensor
The R34 GT-T features : Stock BOV, Aftermarket Pod Filter, 3" Turbo dump pipe, Stock Intercooler, Splitfire Coils, Ngk Iridium Spark plugs.
I'm thinking of getting rid of it after spending so much on it but still no mechanic can diagnose this for me.
What do you guys think ? Thanks !
I'd say your first thing to do would be to take it to a mechanic who has a decent scan tool and find out what the codes are and mean.
I would be concerned that you thought that you could or should "clean" the O2 sensor.  I wonder how you would do such a thing.
My very first thought was that your idle air valve is sticky or borked in some way.  How did you clean it?  Total disassemble and clean with throttle body cleaner?  Or a quick spray and pray?
Did you adjust the TPS back to the absolute correct position when the new one went on?  It should read ~0.45v at closed throttle.
  • Like 1
Thanks for the concern, no engine light comes on and all I did with the 02 sensor was pulled it out and left it in a small bucket with petrol, after that I cleaned it with a paper towel but still same problem.
With the Idle air valve I took it apart and gave it a throttle body spray.
The TPS was installed by a professional mechanic and yes it’s adjusted correctly but still stalling so the TPS is not the problem.
I’m going to try and replace most of the hoses in case it’s brittle and might have some leak especially around the BOV and see how that goes.
Just you let you guys know that this problem started occurring when I got my radiator changed to a ALLOY so it was a bit bigger then the original factory one. After the radiator changed, there was a Transmission hose going from the radiator to the transmission cooler and that was bent to the point where it burst and started leaking and I was stranded and had to tow it home because the gears stoped working. Found out the hose was bent so much it crippled and didn’t allow the flow of the fluid to pass properly, (right angle bend). After I replaced it and made it more straight so it can flow better, It’s still had the same problem. That’s when I started trying to diagnose deeper by changing coils, afm and etc
There are anywhere up to 5 CUs in the car that will give you codes.  Absence of the engine light on the dashboard just means that the ECU is not upset.  The TCU (which happens to be inside the ECU , but is still a separately addressable CU on the car's bus), the ABS, TCS and HICAS CUs are all also on the bus and can give you fault codes.  Given that your problem appears to be trans related, it would appear wise to interrogate the trans computer, wouldn't it?
Advice stands.
Your O2 sensor is now f**ked, by the way.
  • Like 1
So I replaced my O2 Sensor and the old one turned black. But even then, my car still stalls when I shift into reverse or drive like you said :(
I booked my car in 2 weeks at a different mechanic, one that specialises diagnoses. I’ll keep everyone up to date Image1531207928.978964.jpg
  • 3 weeks later...
  • 5 years later...
  • 9 months later...
HA!!! Having the same issue so dropped the car off at Chasers Performance to get the codes.
I could never give it gas while turning. And it stalled at lights for the first time on my way to the mechanic today!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
