Charcoal 1992 R32 GTR
Full Nismo body bits ie Nostrils, air deflector on bonnet, skirts and lip under rear spoiler. Body and paint are in good comdition.
18 X 9 Enkei RP0's 26535 tyres, legal tread
tints
Power FC, cam wheels, Blitz DSBC, catch can, front pipes and cat back exhaust (Comfortable sound levels), 215kw atw's CRD Shootout mode.
Whiteline Works Suspension Kit.
Standard brakes, rear slotted DBA's
I have brand new AP 6 pot calipers and rotors to suit 32 GTR for sale also.
Complete set of white Nismo Gauges 11000rpm and 320km/h, which includes sub meters.
Momo wheel
Nismo shift knob
MP3 CD, splits, parcel shelf speakers, sub and amp
The car is in canberra and has act registration.
$25 000 negotiable.
email [email protected]
or telephone mobile 0410 547 546
No time wasters please.
https://www.sau.com.au/forums/topic/47450-gtr-r32/
You wouldn't believe it the car came from Perth!
We'll refund your airfares if you buy it hows that!
I think it costs about $600 to freight it.
Cheers
Simmo!!
I'm shocked, that car took you ages to find.
I can vouch for the fact that is an exceptionally clean car( unless he's crashed it without telling me :rofl: )
Reason I know is I sold it to him and boy was he fussy when he flew over .hehe
If he is as pedantic with looking after it as he was with buying it, that is a bloody good buy.
Good luck with the sale Simon and I wonder what your getting next.
Cheers
Ken
https://www.sau.com.au/forums/topic/47450-gtr-r32/#findComment-959666
  • 3 weeks later...
Howdy Ken hope things are well .........
Yeah car is still very tidy mate, but circumstances change and I think I need to make way for a race car!
Thanks mate
.......car is still for sale by the way.
Cheers
Simmo
https://www.sau.com.au/forums/topic/47450-gtr-r32/#findComment-983927
Also comes with the original wheels with good rubber.
I also have the cam wheels cover, and the shield that runs between the cam covers.
also a complete silicon intercooler hose kit.
.....and all original guages.
Cheers
https://www.sau.com.au/forums/topic/47450-gtr-r32/#findComment-1002523
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
