So the other day I took my 34 gtt to work, it’s running a 3076 6 boost power F.C. and z32 etc etc, got to work fine which was a 8 mile basic commute with the last mile a poor road surface
anyway came out of work to drive home and noticed a miss or a bit lumpy, looked down at the wideband and it’s running 18 or so to 1. So very lean. From idle to cruise right through its lean
I went into the power commander fuel adjustment and dumped the fuel in up to 1.3 to get it running smoothly and back to about 15:1 and limped the car home
so first investigation was car seemed low on fuel so chucked a can in, in case it was to low,
also inspected some hoses and noticed the pipe on my z32 afm to turbo was not sealed perfect, it wasn’t off much but I squared it up and tightened it anyway, started the car and it seemed spot on so assumed it was fixed, 15 minute test drive and all was fine so put the car back in the garage
Went to take it a run tonight and reversed it out of the garage and it’s lean again, at idle and through revs do just put it back in the garage,
any pointers ?
its a fairly recent top mount turbo install and map, 300zx fuel filter and a new Walbro was fitted at map time 500-700 mile ago just. Injectors are r35 gtr and also low miles. Voltage still regulates for pump so would like that hard wired,
I want to swap a different z32 in too just to rule it out but any other ideas ?
Edited by Eager
https://www.sau.com.au/forums/topic/474640-running-issues/
Oh I know, it was just to get me home, but even I richened it up there was no missfire present
but certainly no missfire is evident, and on the 15 minute test drive the other night it ran perfect. With power F.C. on its map just, no adjustment, I thought the pipe adjustment sorted it as it ran perfect
At idle there tonight it’s stable just lean, not missing
Edited by Eager
https://www.sau.com.au/forums/topic/474640-running-issues/#findComment-7882524
Ok
so ive had another look around the engine bay and noticed there is a loom that runs along the suspension strut area, off it comes a few things like the o2 sensor, stock boost solenoid plug, it runs over to the afm and then into the wing, maybe headlight?
it seems a bit charred, it’s not completely burnt but certainly has had some heat from the top mount install running fairly close
can anyone tell me is that part of the main loom or is that a piece I could replace easily ?
It might not be at fault but it doesn’t look great
Edited by Eager
https://www.sau.com.au/forums/topic/474640-running-issues/#findComment-7882556
Sooo done a quick compression check. She isn’t good boys lol.
What’s the official number order by the way?
1 being at radiator, in this case below, 6 at bulk head
Results on cold engine
140-150 odd on 1,2,4,5
3 gets to 140/145 but takes a few extra cranks. 6 is 60 or so and jumped to 70 odd with a little oil in the cylinder.
Going to do a leak down test and bore scope next to decide what is leaking. But the car runs fine, revs fine and has no misfire or nasty noises once the fuel is adjusted on the hand commander.
Edited by Eager
https://www.sau.com.au/forums/topic/474640-running-issues/#findComment-7883451
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
