Hello everyone!
After stupidly having my Gt-r sitting in the garage doing nothing for about 2-3 years I’ve tried to give it a run. I changed the oil and oil filter and tried turning it over with no success (surprise surprise). My battery is fine and it’s got fresh fuel.
As I turn it over I don’t get any oil pressure on the gauge, is that expected? Will I only get pressure once it starts? Bit of a noob tbh. I’ve read that the gtr oil pressure sensors are dodge city, could that be stopping it from starting?
Im going to check for spark but I’m worried it’s full of sludge. Can anyone point me in the direction of a good mechanic in Sydney’s south?
Any help is appreciated!
Thanks!
https://www.sau.com.au/forums/topic/474870-gtr-won%E2%80%99t-start-help/
Shouldn't see oil pressure on gauge while cranking.  Is the fuel pump priming and stopping like it should when you turn on the ignition?  If not, could be dead/seized from inaction.  Injectors could also be stuck closed.  Does it fire in any way at all, or just cranking with no chugs?
Ok cool, that’s a bit of a relief at least. Yeah the fuel pump primes when I turn it on reds as expected. Doesn’t sound like it’s firing, just cranks on the starter motor, I need to check for spark right? Does the ecu rely on the oil pressure sensor to start? I also thought it could be the ignition module since that’s gone on me before but after buying a new one I tested my old one and it was fine (face palm).
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
