Hello everyone!
After stupidly having my Gt-r sitting in the garage doing nothing for about 2-3 years I’ve tried to give it a run. I changed the oil and oil filter and tried turning it over with no success (surprise surprise). My battery is fine and it’s got fresh fuel.
As I turn it over I don’t get any oil pressure on the gauge, is that expected? Will I only get pressure once it starts? Bit of a noob tbh. I’ve read that the gtr oil pressure sensors are dodge city, could that be stopping it from starting?
Im going to check for spark but I’m worried it’s full of sludge. Can anyone point me in the direction of a good mechanic in Sydney’s south?
Any help is appreciated!
Thanks!
https://www.sau.com.au/forums/topic/474870-gtr-won%E2%80%99t-start-help/
Shouldn't see oil pressure on gauge while cranking.  Is the fuel pump priming and stopping like it should when you turn on the ignition?  If not, could be dead/seized from inaction.  Injectors could also be stuck closed.  Does it fire in any way at all, or just cranking with no chugs?
Ok cool, that’s a bit of a relief at least. Yeah the fuel pump primes when I turn it on reds as expected. Doesn’t sound like it’s firing, just cranks on the starter motor, I need to check for spark right? Does the ecu rely on the oil pressure sensor to start? I also thought it could be the ignition module since that’s gone on me before but after buying a new one I tested my old one and it was fine (face palm).
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
