Missing under load, white smoke, stops missing when warmer, still residual smoke! This started about 100klms after a dynotune.
I don't really want to fork out another $1200 until I have a rough idea what the problem may be. Any ideas?
Car has a Haltech Platinum Pro ECU and a single Garrett 3076R turbo.
Tardo
https://www.sau.com.au/forums/topic/474872-gtr-r-32-smoke-after-dyno/
Hey guys, amazing what a bit of investigating can do. Found a corroded and leaking coolant pipe under the intake manifold, which probably explains the white vapour/smoke. The missing under load was caused by a cracked spark plug on number 4 cylinder. I thought a head gasket issue was unlikely cos they're pretty bullet proof on the 32, so glad I didn't rip into it!
Tardo
Tardo
Good result. If you are replacing pipes under the intake manifold, do them all in one go. Kudos Motorsport sell a kit. I even ordered OEM hard lines and replaced them while at it and the parts that plug into the block. And to add, knowing corrosion has started on that side in the coolant pipes, the turbo side will only be a few months away from doing the same so if you are going motor out I'd go to braided lines on that side too.
Also where do I find one of these bullet proof head gaskets?.. haha.
