I have an R33 GTR seat set, 2 x front and rear bench.  I think they are out of a '96, they have the mauve/purple inserts in the headrest.
The top part of the rear seat was sun affected [ie faded and UV weakened/rotted] so I took it to a local upholstery business and it has languished there for a few months now.  They can't seem to find the grey brushed velour [not the centre inserts, we will be able to re use them] that is endemic to nearly every model.  So I am looking for a supplier that can sell me 3 metres of this material so I can get the seat finished.  Ideally I would go to some other business that can do the job but this would mean a long trip cos I live in a small town in the country, Sydney is 4 hrs away, Canberra is 2.  Plus I feel that if I can find the right material then the upholsterer should be able to do the job [surely its not that difficult].
So does anyone know of code numbers I can ask about [okish], or a supplier [better]?
TIA
https://www.sau.com.au/forums/topic/474930-recovering-rear-gtr-seat/
Hey mate, I too had similiar damage to my rear seats. It will cost too much to get them fixed and chasing a perfect colour match will be difficult. I would suggest you looking on eBay, Gumtree and the Sales section of this forum to buy used seats and just replace them that way.
Cheers,
lol....the fabric is available, I've had a section redone before [albeit around 10 years ago].  And the seats are going in my Gtst.  Buying used will turn up the same issue, all the rear seats fade across the top.  The rear window glass just lets that sun in big time!!!
I also have a set of genuine factory leather seats out of a SIII '98 R33 GTR that I've had refurbished [still have to remove and recoat/powdercoat the carriage to finish].  But was hoping to get the grey velour ones sorted as well.  leather is OK in the winter but burns like f#*k in the summer ?
I cheated and bought ridiculously expensive Nismo covers as the stitching kept bursting and material fading.
In some ways, I would love to keep the stanard R32 look but *every* time I get out of the car, the jeans on my fat arse rip the bolster
  • Haha 1
Can you post some photos of these "ridiculous expensive Nismo covers"?
6 hours ago, Robzilla32 said:
Sample pic
They actually look quite very nice. Where did you get them from?
Nengun Performance has them for a crazy $1,700 plus postage. Wow.
https://www.nengun.com/nismo/seat-cover-set-skyline-gtr
Edited by Robocop2310
Those covers look very schmick Rob, but - to me - its like hiding rust with new paint.   And I can't afford $1700.  The material I want will cost much less than that, but just have to find the right knowledgeable person to help me source a supply.
2 hours ago, tridentt150v said:
Still trying, still asking?
Give these guys a call. A mate of mine had a friend that had his seats repaired by these guys and he seemed happy. I have never used them personally but have  chat with them and let us know how you go.
https://www.gumtree.com.au/s-ad/revesby/other-automotive/car-seat-upholstery-repair-sydney-leather-car-seat-repair/1101453969
  • 1 month later...
You can get new seat covers made. They will make it to suit the new seat and they stitch it into the existing seat so they won't move. Just got mine done, however I'm in Melbourne.
The ones you posted from the website is a cover. You need to dismantle the seat and insert the cover on each section of the seat.
The one RoboCop sent the link through will custom make the covers and will do the same. Dismantle stitch into the existing seat so it doesn't move.
Who did you use mate and can you please post some pictures?
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
