Hi first time posting on here after many hours of reading trying to sort my r33
Okay its a r33 rb25 series 2 and it randomly starts misfiring really bad, it will splutter, or if on full throtle it will completely hit a flat spot again and again and it even cuts out at times. Plugs are fine replaced the cheap ebay coilpacks to stock ones and even replaced the cas, was thinking harness but when running you can pull on it and it wont missfire. Thing is it does it randomly like on a few odd ocasions it will run absolutely mint no problems at all then it will run so shit like some days it will cut out over and over again...want to get to thw bottom of this, any help is really apreciated
https://www.sau.com.au/forums/topic/474933-please-help-missfire-and-cut-outs/
Okay its an auto, nothing major on mods just the usual aftermarket intercooler, pod filter, boost t and exhaust runing about 11 psi. Okay so when  it does it on idle it blows black smoke cause not burning all the fuel and can cut out whenever, for example other day i pulled out my drive way and it cut out twice doing like 15..... fuel filter has been changed and dosent matter if tank is full or not, thanks for the response  guys
  • Like 1
Hmm sounds like a fuel issue, maybe put anothe quarter tank of 98 and see how she runs? One of my 33s would start to cut out at around 1/4 tank then not start once it had reached just under a quarter before the low fuel light even went on (probably the owner messing with the fuel gauge needle when changing the cluster bulbs or your fuel filter needs replacing/fuel pump is on the way).
Or it could be a vacuum leak since mine blows black smoke and cuts out really bad when one of my intercooler pipes blow. Are you running the stock blow off valve plumbed back? May have issues idling/starting without the stock bov setup if running stock ecu.
Also if its mainly happening on wide open throttle, lower your boost to 8 to test if the ecu is going into 'rich and retarded' mode.
Also what spark plugs are you running? At 11psi they should be gapped to around 0.8mm (alot of people recommend NGK BCPR6ES plugs).
Also look at your coilpacks if they are factory/ebay ones. I had a splutter on 75%+ throttle running 9psi and wrapping my coilpacks with silicone tape fixed it.
Just read your response, could possibly fuel pump? It sounds like something small to be honest so maybe take it to a known mechanic/a jdm shop/tuner and have them look at it before you spend any more money. If they quote you a ridiculous price, at least you'll know what your issue is.
Just last week my auto 33 turbo was having the same issues without the smoking. I got brand new NGK spark plugs as mentioned above, i taped up all the coilpacks with electrical tape (3 were red Ebay ones and 3 were stock ones, all looked fine to the eye but probably had hairline cracks). The boost was 10, i completely removed the boost tee and ran straight to the actuator to elimate issues with it (some are fakes and some just work shit, just run stock boost until you sort the issue).
I thought it could be boost and putting ecu into rich an retard mode but can happen when not on boost at all, dosent matter if tank is full or quater and is not dependent on throtle can happen at all throtle positions, has stock bov and have replaced a full set of coils to stock ones and the car they came of had no missfires or anything..the reason i dont think its fuel is because it just does it randomly like other times it goes hard
Check the plug to your ECU, I had a similar thing and it was the plug.  They only have a single centre bolt and can sometimes twist off on one end.
But personally I'm with Kiwi, take it to a garage and ask them to check the fuel pressure while you're at it.  Its a 5 minute job.
  • Like 1
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
