Hi all, looking for suggestions,
I'm hooking into my Links G4 can bus with a home brew module consisting of a PIC micro controller + CAN controller / transceiver that will give me up to 8 x 0-5V analog outputs and a few digital in / outs. Sum total of parts $15. (Programming and development..... lots of hours, but my time is free)
I have tested a VDO oil pressure gauge and I can successfully mimic the operation of the sender via PWM and 1st order filtering to a transistor that provides the current sink for the gauges sense terminal.
It's not an elegant solution but it works. What I am looking for is a gauge that takes 0-5V and is available in a range of common display types like oil / water temp, oil press etc.
I've been googling around, but nothing is coming up? I have seen dedicated canbus gauges but they are so overpriced and I am not sure if the Link CANBUS operates to a particular automotive standard for its peripherals that I already have hanging off the bus so they may not work.
Any suggestions for 0-5V or something similar?
Edited by hjtrbo
https://www.sau.com.au/forums/topic/474968-diy-canbus-gauge/
modern "three wire" oil pressure transducers are often 0-5v (0.5 to 4.5). so a guage designed for that could work for you.
iirc on a 32 the factory nissan boost gauge is 0-5v as is the ATTESA front torque gauge.
if you can build the gauge from scratch  then switec low current stepper motors are popular for this sort of thing and can often be driven directly from the mcu (used on GM cars).
I built a can guage to work with my link g4+ a couple of years back and used a 1.5" oled display rather than analogue gauges.
OK, good advice.
I pulled apart my VDO moving coil gauge. Looks ripe for one of those steppers.
Let me play and i'll update the thread in due course.
Edited by hjtrbo
  • Like 1
OK, good progress.
Data is getting sucked out of the Link and the stepper motor moves. Just got to link the two together in software with a bit of scaling and position tracking, add a bit of glue in the back of the gauge, press on the needle, and she's done! DIY can bus gauge, best $30 (so far) ever spent.
https://au.rs-online.com/web/p/microcontrollers/8802680/
https://www.ebay.com.au/itm/MCP2515-CAN-Bus-Module-TJA1050-Receiver-SPI-Module/302496093646?hash=item466e2c15ce
https://core-electronics.com.au/automotive-gauge-stepper-motor-x27-168.html
20181005_123330.thumb.jpg.5c622251c3a316856fc55b3e1c3b2cf1.jpg20181005_123445.thumb.jpg.bfe2721a665fa1c7a36c1f4e650057c2.jpg
20181005_122352.thumb.jpg.5ffbc4cb8f4ac507e2b9e7e660ab7ccd.jpg20180930_162012.thumb.jpg.0478a87f10a36a8060431a3d05e8611b.jpg
  • Like 2
  • 3 weeks later...
  • 3 weeks later...
You don't need extra senders etc on the engine for multiple gauges. Just pull the data out of the ECU. Saves a few hundred dollars and it's fun to learn about something new.
My boards have arrived from China. Will be soldering them shortly. Will post pics and you can pm me if you want to buy one.
  • Like 1
Ok, got the first board soldered up. The canbus module (blue board) then piggy backs onto the board. Still waiting for the mounting standoffs to arrive.
The 4 way terminals are for 2 x stepper motors (2 gauges are supported per board) & 2 x current sinking optically isolated general purpose IO (e.g square drive for RPM or speedo, ECU fault light, shift light etc etc.)
The 2 way terminal is 12V in, and the 3 way terminal is for programming the PIC microchip. There is a jumper to select between run and program modes.
There is a 5V on board regulator with high frequency bypass pass caps for the IC's and large 2 x 470uF decoupling capacitors to help provide a solid power supply to the board. Reverse polarity protection is by the simple inline diode method.
Still got to get the gauges assembled then hook it all up for a decent test.
20181124_131006.thumb.jpg.dc0afc6d829c7d736eff678a49a1e61e.jpg20181124_131015.thumb.jpg.645b85e7b399833cd498d8bc6844012e.jpg20181124_131030.thumb.jpg.b2352275e1f7411d11c80cea7c091170.jpg
  • Like 2
Nice work...I've been trying to come up with a similar solution for my bus. I plan on using VDO style senders to an Arduino and then digital potentiometers on the output of the Arduino to make the gauges on the original dash work.
I'm going to give your little project a go though...I've got 3 Empty gauge holes that need filling in my Supra and those can-bus ones are really parking expensive!
Incase you're curious, the arduino project of mine can be found here:
https://github.com/hotswapster/bedford330
It will also have stuff you can use on other vehicles swell.
Progress is going well, but I wanted to update the thread with some learnings that I would employ in hindsight...
  • For 12V reg use LM2940 (thanks to alexj for suggestion)
  • No need to remove the air core meter and muck around replacing it with a stepper.
    • Consider this method: Instead, cut the resistors off the internal meter terminals, then bring the 4 terminals outside of the gauge body. Then wire them to a CS8190 Precision Air-Core Tach/Speedo Driver with Return to Zero IC.
Hope this helps others on their google knowledge surf.
Edited by hjtrbo
  • Like 1
  • 2 months later...
I redesigned the board to allow for 3 stepper motors, additional IO and changed the colour to match the MCP module off ebay. I used a spare PIC to act as the can bus master to simulate random data.
This setup is for a Link ECU. I doubt it would take much (if any) modification of the source code to make compatible with Motec. The terminal blocks to the right of the board are provision for switches, shift light, warning light etc etc.
All working now. Car is still getting built so will be a while before they are installed into the dash.
A short video of them working...
  • Like 1
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
