Hey so we found out that the car is being flooded with gas after stalling or being driven around a lot, the plugs were soaked after testing it. So sounds like things aren't getting hot enough in the ignition system, do you think it needs new plugs and coilpacks? if so what types should I get? I've heard about people running ls1 coilpacks in the rb25
https://www.sau.com.au/forums/topic/475197-flooded-rb25det-new-coilpacks/
"Things aren't getting hot enough" is that what your mechanic really said?
I think you should look a little further to the intake side of the motor and determine if some donkey has fitted larger injectors to a stock ECU or scaled your injectors incorrectly with your aftermarket ECU.
If your car is completely stock then i suggest you look a bit deeper and diagnose if your AFM and narrowband O2 is cooked, if so your short term and long term fuel trims would be contributing to your plugs fouling. Nothing to do with things aren't getting hot enough, it's not a bbq.
