hey guys
So its been about 2 months since I bought my first car which is an NA 1995 r33 gts coupe, So its about time I finally introduce myself. My name is Jonah and Im 17 from QLD. I recently got my P plates and purchased my first car which is an R33 GTS Coupe.
It looked a bit rough when I first bought it as the paint was disgusting and fading. The car is completely stock with a slow RB20E. Since owning the car I have fully repainted it the original colour and have also managed to get an RB25DET exemption for work but we will discuss that later on. Whilst it was getting painted I also had my mate who is a panel beater help me repair all of the dents in the car left from the previous owner.
Now the cars dents were repaired its off to get painted.
The finished results are amazing as the cars exterior looks pretty much brand new. Now onto my future plans. I have recently acquired an exemption for an rb25det skyline with help from one of my mates. And because of that im in the process of purchasing the new engine to put into the car. I have my mate who is a mechanic coming up early February to help me do the swap as he has done it himself twice now on his own skyline and on another persons. One other modification I will look to be doing in the near future is an auto to Manuel swap which I will most likely do at the same time as I swap the engine. I look forward to being a member of this community and would love to hear your thoughts on the project.
Cheers, Jonah
  • Like 2
https://www.sau.com.au/forums/topic/475485-fizze-introduction/
Welcome!
Smart moving doing a full rb25det swap, rather than +t to the de, manual swap at the same time definitely makes sense.
Are you similarly going to be upgrading the brakes to turbo or better version as well? I assume this would be required for engineering anyway.
A lot of p platers will be interested to know more about this if you care to divulge more info.
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
