G’day my name is Mark and have just recently signed up this forum. My bro n I have been building cars together for 20 years and he is currently building a Ford Escort RS 2000 with an SR20DET Motor!
i have a Navara D40 yd25 but with diesel prices as they are and the age of the motor I am looking to drop in it a VQ30DET motor. Yep, I know haters are gonna hate but I have done extensive maths and research and I think I can do it! I know it’s not going to be a stroll in the park, but hey when is a transplant ever easy!  So, in the very not too distant future will be looking for an engine with harness and ecu.
https://www.sau.com.au/forums/topic/475497-new-to-this-forum/
8 hours ago, Robocop2310 said:
Is a modified GTR illegal?
Keep it stock-looking and a sleeper, I reckon.
There is a difference between bolt on type mods vs a completely different engine though, especially when it comes time that it cops a defect you have to reverse an engine swap, which likely will not happen and the car will be retired.
  • Like 1
Fair point mate.
  • Like 1
If the above were to happen, can you head down the full engineering route?
Asking for a friend... [emoji23]
Depends. Pretty sure there is an overriding rule you can't put an older engine into a newer car,  so in this case it would be a problem as GTSBoy has already mentioned.
  • Like 1
Sort of, you cannot put a old 80's rb30 from a VL in a 90's R33, but, you can if it has the 25/26 head and associated fueling and emissions stuff.
Plus I believe if you register it as a ground up built kit car, you have some leeway, engineering out the wazzo though, I'm thinking back a few years now so things may have changed.
I belive the main concern is meeting current emmisions standards, which with some cane juice and tuning shouldn't really be a concern.
Happy trails
  • Like 1
