Hello
I have for sale:
* rb26 Hypertune intake manifold
*hypertune 90mm throttle body
*accelerator cable to suit GTR
*haltech TPS
*nissan rb26 AAC valve
Hypertune manifold and throttle body only 2 years old, very good condition, very tiny small marks not realy visible
excellent overall condition.
Still on the car will be removed over the Christmas break
pick up from Sydney or can post Australia wide
Will accept deposit to first serious buyer to hold it for them till it’s removed
$1300
https://www.sau.com.au/forums/topic/475619-rb26-hypertune-intake-plenum-setup/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
