  • Replies 40
JiMb0, but you can change it to top views for both driving in the car and walking..
played it to death on the PS2 but on PC its just not quite the same, I guess I need a PS2->PC controller to get the best out of it. get it thought, tis an awesome game just running around for hours killing people, evading the cops + feds, blowing up helicopters and doing your worst to little grannies walking on the street :)
bitch'n game.
Shaun
https://www.sau.com.au/forums/topic/476-gta-iii/#findComment-12645
kazaaa ... pfft, poor mans perm distro :) You never know what you might catch from kazaa George, it's dirty ..... then again, if I were kazaaa I'd prolly be more afraid of what I might catch from you :wink:[/quote:0e3d3fd8f7]
LOL
it's alright. i run ad ware stuff all the time. i always get more hits with kazaa anyway. i tried a gnutella one, limewire and bearshare, but didn't get many hits.
what do you recomend?
https://www.sau.com.au/forums/topic/476-gta-iii/#findComment-12653
LOL
what do you recomend?[/quote:044b83e6c0]
edonkey
eDonkey2000
get all the latest release stuff from
ShareReacter.com
on modem its a bitch at first as it takes ages to find a server and connect but once its going its alright, broadband... its a dream. :-)
Shaun
https://www.sau.com.au/forums/topic/476-gta-iii/#findComment-12654
