*Wrecking*
R34 skyline midnight blue
*(parts only)* *more parts not listed*
Prices negotiable!
Seats 300 lot front and rear
Seat belts 30 each
Boot lining 80
Bonnet 550
Boot lid 220
Motor ecu & box 1200 sold
Front strut brace 110
Tail lights 400 or 220 each
Headlights 550 sold pending payment
Front bumper 350 sold pending payment
Rear bumper (silver) 120
Front gaurds 200 set fl60(dent) fr140
A.c. fan 25 sold pending payment
Throttle cable 20 sold
Radiator 70 sold
Radiator shroud 30 sold
Locks and keys 100 sold pending payment
Door outer handles 20 each
Door interior trims 30 each
Window switches 15 each
Driver door electrics control 40
Door inner handles 15 each
Center console 60
Cluster (@220k) 100
Dash 200
Glove box 35
Kick panels 10 each
Sunvisors 40 set
Steering wheel with airbag 100
Steering clock assembly 70
Msg for more parts and prices I will respond asap.
No emails please. Scammers reported!
Zaq - 04382three511six
[email protected]
https://www.sau.com.au/forums/topic/476008-wrecking-r34-na-sedan/
  • 3 weeks later...
Staggered and dished 18" speedy inferno rims / mags .
1 has a small buckle on the inside which has never caused me any issues and always balanced up in the 5 years ive used them. Makes any car look and feel instantly better. Good tread.
Front 225 40 18 Tread 80%
Rear 235 40 18 Tread 65%
Would love a polish up.
$650.
Currently on the red ford.images%20(4).jpeg20190215_183518.jpeg20171210_175405.jpeg
  • 1 month later...
  • 1 month later...
Bump!
Cant edit the previous post, need bits just ask.
Speedy Infernos have sold
Still have bits to sell.. make me an offer:
R34..:
Seats
Doors/handles/trims/windows
Mirrors
Glove box
Boot lining
Brakes
Tail lights
Cluster 220k
Strut brace
Seat belts
Interior
dash
ect ect.....
Lots sold
Lots left
Just right.
Clearance prices if i have what you need plus postage!
Also have:
Sr20 coil packs x6 $10 neg each + postage
3.5" hi flow flanged cat $20 + postage
Old r32 front and rear seats front with old covers on the and missing some rail bits , tear in drivers bottom right side and bit of glue on the rear midle upright. Make an offer pick up only.
Rb Wolf 3d v4 plug in with pc usb to serial cable... askin $250 make an offer was gonna use it on my 20 det but decided to stick with stock and piggy back so i dont need it.
20171210_174650.jpeg20171210_175507.jpegIMG_1525384594459.jpeg20190116_131408.jpeg20190202_201402.jpeg20190116_131425.jpeg20181113_205208.jpeg20190226_180723.jpeg20190207_195432.jpeg
  • 1 month later...
  • 1 year later...
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
