Greetings, after a long absence, comes time to seek some advice from those more experienced than myself. Must say that I do peruse the site from time to time to keep informed. Anyway, my issue is this; For some time now, especially when travelling on a particularly smooth road surface, and more so at a slow speed, I have noticed a faint thump thump coming from the front part of the car On the rougher road surfaces it was not an issue. It is a great car, used on special occasions, had never done anything that I thought would flat spot a tyre. The car handled exceptionally well, and the issue never really bothered me. The front tyres on the car have done about 20k kms, are of Chinese origin, still have 2 or 3 mms left above the wear bars on them and have never given me doubt in their use. They are 225 40 18's, so a slightly lower profile than std.  Looking at the tyres through the wheel arch, I have often thought how well they have served and never noticed any abnormality. I do the servicing of the car, am under it - on my back, every 5k kms and have never noticed anything wrong - this episode makes me wonder. About 20k kms ago, I replaced the lower control arm bushes with Superpro ones, all seems ok there still. Following that, the alignment data worksheet seems to indicate that the measured settings were close to those listed on the G35 Service Data sheet.
So, that is the setting, now to the present. The car did the near 2k km return trip to the Bathurst 12hr last weekend. Wasn't the fastest on the road, but it did some spirited driving  when conditions suited, like over Falls Creek. On the concrete section of the Hume, between Gundagai and Albury,  the thump thump became more prominent. A slight tendency to veer to the left also developed.
With the car home, thought it was now time for an investigation. Ha! still never doubted the tyres, took them off the car now up on blocks, and set them aside. Was overcast yesterday, a bit dark, getting late in the day, so I didn't bother getting too involved with looking for issues. Happened to move a tyre out of the way to do something else, that tyre being the worse of the two, and got a BIG shock.
I have seen tyres in the past that wear off on edges, but just can't understand how the wear pattern on these tyres originated. The acute wear section is inclined to be more down the side a bit, and on the better tyre of the two, the wear is smooth as though it has been seared with a hot flat surface. Yet then, in some smaller sections the wear is not a smooth flat surface, but looks like it has been scolloped out with a tool like that to get icecream out. The other tyre - wow! I should hang that one up as a momento.
There are known issues with these cars scrubbing out the inside of the fronts because of negative camber and there being no adjustment remedy. e.g. http://forums.redflagdeals.com/negative-camber-g35-559280/      That the car has 40's instead of 45's on it could also contribute. But accepting that, it seems to me that the tyres have been rubbing on something, yet there is no indication under the car that such has been happening. Rubbing on road surface?? I just can't get the angles to work
https://www.sau.com.au/forums/topic/476014-any-suspension-gurus-out-there/
Thanks for the response. As a first step in getting this sorted, the car is booked in for  suspension inspection next Tuesday. Yeah, but it seems my problems don't end there. Down the right hand side of the pic with the most damaged tyre, there is evidence of a flat spot on the rim. Ha!, when I posted the pic, thought that it was just a camera illusion, but no, it's real. Have done a bit of research, watched some youtubes'; those that were repaired didn't come up 100%, and the general consensus seemed to be don't do it, - hmmm? Thinking a pipe bender with a couple of curved formers at either end??
So, by now there have been a few hrs spent searching the market for rims. That has included going back through the for sale section here for the last 12 months. Some 17's around, but not so 18's. I'm content with those that are on the car at present and don't necessarily want to upgrade.
Hello,,,,    anyone wanting to sell a pair of Rays 6 rectangular spoke OEM rims for a V35, mine are marked inside: Nissan Front,  18 x 8JJ / 30
I guess in that regard I would be grateful, just in case I have to go with a full set, to know why the rim would be marked "Front"? if anyone can wise me up please.
  • 3 weeks later...
Will tie this one up. First, the damaged rim: ha!, repair it with a pipe bender? well that was a naive statement if ever there was one. Shane at Ace Alloys in Mordialloc, looked after me. The rim was in a bad way and distorted across the whole width, and the prognosis not good. He put it on a spinner and it appeared way out, I can't explain why I didn't detect it in the handling of the car? They have a press that doesn't use heat, and scored a winner, as did I. Spent more hrs researching, and the inbuilt negative camber in the car, and others, is recognized as a cause of premature tyre wear in the region that mine went.  Going down to 40's from 45's even aggravates this problem. I've stayed with the 40's because of vanity, but am trying Goodyear Directional 5's on the front. Will see what happens, but they can be swapped from wheel to wheel, so there is the potential to get wear from both sides of the tyre. Have Eagle Asymmetrics to go on the rear.  The car's suspension components tested out ok. Am now all but out of adjustment for the rear axle. The front toe ins were out, esp on the right side.
  • Like 1
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
