BNR32
Dead stock bar,
- PFC
- Nismo AFM's
- K&N's (dirty)
- Trust PEII cat back (80mm)
Bits
- GT35 Hybrid,
- 6boost manifold, 60mm gate
- Blitz ID III
- 4" zhaust from turbo to cat (then PEII)
- 044 in tank, dedicated +12v feed, twin feed rail, 700cc SARD's, SARD FPR
- Relocate battery to boot, full +12v feed to 044
- JUN 260 cams
- Ogura twin plate
- HICAS lock bar, cooler loop, all lines removed
- Battery relocate to boot
- Coilovers
- Defi's
- Billet oil filer remount & cooler
Edited by GeeTR
this is from when i bought it:
and this is from sitting in my driveway for the last 4 months with a fcuked RB20
mods so far:
HKS 3.5' turbo back exhaust
HKS 5' super dragger muffler
HKS mushroom pod filter
FMIC
Apexi progressive springs
thats all i can think of at the moment.
its going into trojan next week to be fitted with an RB25DET, KKR430 turbo, walbro fuel pump and a couple of other things
goodies going on aswell soon:
Edited by MANG
Hey Hi GeeTR,
just curious if you've had the PEii tested for DB?
that's the exhuast I plan to get in the near future to replace my 3.5inch which is too loud. wanted to know if how legal it is.
cheers.
Michael
Hey Hi GeeTR,
cheers.
Michael
Hey Michael,
Sure do. Came off the boat with a rusted out 3.5", that was almost falling off = 112dB
Put a PEII on tried again, and was much better at 98dB, which they "were" going to pass me for, but then i backed off, anit popped a 107dB on the overrun :)
If the PFC was in it then, i could just tweak the fuel at those values, or decel settings.
Alas, I then gota rear section made up that proved legal at 76dB or something ridiculous.
Conclusion: They are louder then you are allowed, but once past rego i think your fine, as they ARE a v.quiet system. I would suggest theres no way you would get pulled over due to noise. A point to note as well, i have two turbos and more twist and turns in the (stock) front section then those running a GTST. I actually think its too quiet :)
I think most RBs have a resonance tone at 2800-3200rpm ( about where Dickson ask you to rev it to) so this isn't really as loud as other setups that would register 98dB
When i get the 4" from turbo to cat, I might think bout making up a 4" rear section too. Will let you know if your keen on grabbing a 2nd hand system at some stage.
Sorry for long reply ( I thought there was to be no chit chat in this thread? ;) - hope it helps
- M
Hey Michael,
Put a PEII on tried again, and was much better at 98dB, which they "were" going to pass me for, but then i backed off, anit popped a 107dB on the overrun :dry:
Conclusion: They are louder then you are allowed, but once past rego i think your fine, as they ARE a v.quiet system. I would suggest theres no way you would get pulled over due to noise. A point to note as well, i have two turbos and more twist and turns in the (stock) front section then those running a GTST. I actually think its too quiet :happy:
Sorry for long reply ( I thought there was to be no chit chat in this thread? :wave: - hope it helps
- M
M-
thanks for that, i will definately add it to the list of things to buy when
cheers
Michael
Nope, Skylines going ASAP, had it for nearly 5 years, time for a change. plus the utes got more potential for less $ outlay (when warranty's finished)
Now thats what im talking about..
This is exactly y mine is up for sale..
Im goin for a BA/BF Ute. for work and fun.
Nice car mate.
Nice car mate.
there very nice to drive, so many more features and such a more refined car.
I never thought it would happen, but i now dislike driving the Skyline after the ute
looked at a BF ute, but just cost too much for what i wanted, plus losing so much just by driving it off the showroom was a detterent
they are a nice car to drive..
I was looking at an F6 Tornado. Hot ute..
Great to drive, but yea bit expensive for what i need it for.
Seems like the old school SAU'ers are moving to aussie built cars (looks at the VZ Clubsport sitting in his garage).
I agree with you though, both the newer Ford's/FPV's and Holdens/HSV's are nice cars and now that they actually have decent performance and reasonable handling, can take it to most of the JDM imports. I was actually quite stunned when the Clubby put down a GTR not once, not twice, but three times a few months ago.
Edited by Amaru
Bah you just need to go to a newer Jap car (looks in the direction of an Evo :domokun:)
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
