Oooh who is doing it?
There's a guy on Canberra Cruises that has a pretty awesome blue Soarer. I have a bit of a soft spot for them.
That would be Aaron,
Getting David Hand to do it...who knows how it will come out, but my insurer guarentees the work, so if it comes out bad, it will be going back until its perfect.
As zeb said. you need big turbo for 260rwkw
Nistune for like $200 (i can do the soldering)
Tune for about $150-$200
$350ish and you'll be at 210ish rwkw
Your on. We'll do this sh!t.
Who do you trust locall to tune my daily ?
Ambitious on an op6 then huh ?
If it has GT30 internals it MIGHT get there.
Max realisticly would be 200rwkw.
Then again with all the happy dynos in Canberra you might infact end up with a dyno sheet that says 450rwkws lol
lol... prolly...folk here are just awesome hey!
I get CRD to do mine for the 32. But solid beleiver that it's how it feels to me on the road that i measure against. When it has more than I'm comfortable with then thats nuff for me.
Edited by Sinista32
Ed at autotech has tuned mine 3 times, never had an issue with anything (There is a few bad stories going round about him, but they're all on big hp numbers).
He's familiar with the nistune software and has done a good number of nistunes.
If all is well with the car it should only take an hour on the dyno.
With the stock turbo it came out at 215rwkw at 11psi. on a dyno that i know for a fact reads lower than ESP's
Thats still very high for a stock OP6 lol..
My highflow 21U made 200rwkws at 13psi on the hills motorsport dyno...and was backed up by the big black dyno
Gotta love canberra dyno's
should through my Soarer on one and see what it comes out as.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
