Danny im sure i've seen your car at the anu before and pee'd on it. Its a pretty good spot for photos at night.
Are you a student there?
Yeah I went there for a couple shots of my car recently, but nah I'm actually still in college lol.
^^^fixed.^^^
Tis a fine looking piece of machinery. :thumbsup:
Hahaha ! thanks for that :P
  • 5 weeks later...
  • 1 month later...
Hey Guys,
Im not very active on SAU, but thought I'd post my HR31 Coupe, hoping to get back amongst it, since the R31 scene is pretty well dead (well 3 people in the ACT, everyone has pretty well moved on).
I've recently finished a major cleanup of the outside of the car, as well as a conversion from the standard redtop RB20 to a Silvertop, loom & ECU. All the work has been done by myself and my mates, and I'm really proud of it.
Some pics at the Skyline Nationals in Goulburn:
with the 180:
I have some future plans for it, mostly continuing to restore it to as good condition as possible inside and out, and also some new bearings and rings for the motor, with a GTS-R Manifold, T04E, R33 side mount intercooler, external 38mm gate, and exhaust. Not really aiming for a power figure, but expecting around the 200 at the wheels on 10-15 psi.
I also have a black 180SX which I like to do skid pan days, track days and drifting events in, a VL Calais Turbo which I'm fixing up, and another R31 which I drive to work.
Hope to see some people on the weekend at the Snowy 1000 :)
hey guys
new to sau been on here for about a week now
have never been happier with a car the stagea is everything you need and want rolled into one :D im always keen to help anyone out mechanically or with planning a.c.t events so dont be afraid to ask
hey guys
The stagea is a great car. My mate Verms has an autech one. Great space and great power! the 26dett in those things are nuts.
  • 3 weeks later...
Hi All,
My name is Brad. Long time reader, first time poster here.
Been frequenting the SAU forums for the past few months, until I finally registered as a member when I decided that I would take the plunge and get a Skyline of my own!
It took me about 2 months or so of searching, enquiring and inspecting many different R34s from all around ACT and NSW before I eventually came to own my "almost perfect" R34 GT-T.
I have had it for a couple of weeks now but haven't got around to posting on here till now...
2001 Model - Series 2
Pearl White
85,000 kms - not sure if genuine, but great condition leads me to believe it may be.
Manual
Factory Sunroof!
Basically 100% stock standard except for HKS Turbo timer and rear adjustable control arms and bushings (which I had installed).
Came with 20" rims on it and a spare set of 100% brand new stock rims which I have put on as I was not a fan of the 20s.
http://i1288.photobu...4/BradD54/8.jpg
http://i1288.photobu...4/BradD54/7.jpg
http://i1288.photobu...4/BradD54/3.jpg
http://i1288.photobu...4/BradD54/5.jpg
http://i1288.photobu...4/BradD54/6.jpg
http://i1288.photobu...4/BradD54/4.jpg
http://i1288.photobu...4/BradD54/2.jpg
http://i1288.photobu...4/BradD54/1.jpg
Note the number plates which I am stoked about! Just got lucky when I had to transfer rego.
Current plans for it are:
Remove stock solenoid and install manual boost control+boost gauge - as I think it might be overboosting...
Turbo back exhaust - Stock one is a little too quiet/restrictive.
Decent panel filter for intake
Black/dark grey 18" TE37 style rims - can't justify the cost for legit Rays TE37!
Then ECU + Tune once I've got it to a stage I'm pretty happy with.
Will be doing little details here and there, but basically just full "stage 1" mods and then I'll see from there. Just have to get back on top of money now after spending so much just to get it! ;)
The R34 GTR has always been a dream car of mine, and since I cannot afford to shell out for the "real thing" I settled for the next best!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
