Been sitting on residual stock and it's time to move them out. Prices excludes postage, Pick up in Sydney west, postage available unless otherwise stated. Prices negotiable, more you buy, more discount.
All parts stated "New" are old residual/leftover stock and the packaging may have dust, discoloration, opened/resealed etc. however the part itself has never been used.
Genuine Nissan:
New Genuine Nissan VQ25 Rocker Cover Gasket - Pair 13270-AL612, 13270-AQ800  $40
New Genuine Nissan R33 RB25 Series 1 Coilpack Harness Loom 24079-75T00  $200
New Genuine Nissan Windshield Dam Seal G2716-89901  $20
New Genuine Nissan RB Oil Pump Seal 15066-71L00  $10
New Genuine Nissan RWD R200 Diff Gasket - Skyline, Silvia/200SX 38320-40F02  $20
New Genuine Nissan Skyline R33 M/T, Patrol GQ Shifter Bushing 32861-01G00  $5
New Genuine Nissan Gear Shifter Socket R32, R33, R34 (ex. GTR), S13, S15 32870-V5003  $20
New Genuine Nissan Gearbox Shifter Seat Socket Snap Ring 32207-V5004  $10
New Genuine Nissan Gearbox Shifter Retaining Circlip 32204-V5003  $10
New Genuine Nissan Skyline Manual Speedo Sensor Cog Circlip   $5
New Genuine Nissan Skyline Speedo Pinion Gear Cog 32743-30P20  $30
New Genuine Nissan Skyline Manual Speedo Sensor 25010-21U00  $200
New Genuine Nissan R34 GTR Front window lower Insulator 72717-AA000  $20
New Genuine Nissan Rear Tail Light Sealing Sticky Stuff B6553-89915  $20
New Genuine Nissan CV Boot Kit 39241-73L28  $20
New Genuine Nissan PCV Seal Grommet Gasket 11812-41B00  $10
New R34 GT, GT-T Radiator Fan Shroud 21476-AA100  $80
Aftermarket Service Parts:
New Ryco Oil Filter Z145A  $10
New Penrite Racing 10 10W-40 Full Synthetic Oil   $50
New Penrite Pro Gear Full Synthetic Gear Oil 80W-140 20L drum  $250
New Gates Racing Timing Kit RB25, RB26 TCKR1040B  $150
New Ryco Air Filter - R32, R33, R34 A360  $10
New GMB Water Pump - Mitsubishi Colt - 4A90, 4A91 W3168 / GWM-91A  $50
New RB25 Lifters HL6322  $20
New Gates Racing Belt 4PK890R  $30
New Gates Racing Belt 4PK850R  $30
New Gates Racing Belt 4PK865R  $30
New Gates Belt 4PK890  $10
New Gates Belt 4PK850  $10
New Gates Belt - Suits RB26/30, 25/30 build T291  $30
New RB Gearbox Spigot Bushing   $5
New RB Magnetic Oil Sump Plug 12MM X 1.25 PSP100M  $10
New Pro-Torque RB Rear Main Seal NJ287  $15
New Single Camshaft, Crank Shaft RB Seal   $5
Newish R33, R34 Century Battery NS40ZS - Fitted to Customers car, removed 10 minutes later due to non-payment. Will provide 14 day warranty  $80
Used Skyline R34 N/A 2 Pot Brake Pads - Fitted for test drive to diagnose noise and removed   $10
New Bendix DB1220HD - Skyline R32, R33, R34 Turbo models Rear DB1220HD  $50
New Premier Brake Pads - R32, R33, R34 Turbo Models Front PR1170  $20
New NIBK Japan Brake Pads - R32, R33, R34 Turbo model Front 4 piston calipers PN7463  $40
New NIBK Japan Brake Pads - R32, R33, R34 Turbo model Rear 2 piston calipers PN7800  $30
Engine Parts:
New Permaseal MLSR Multi Layered Steel Turbo Exhaust Gasket TUR001  $15
New Permaseal MLSR Multi Layered Steel Turbo Exhaust Gasket TUR015  $30
New RB20/RB25 Turbo Gasket Set - $40
New ACL Race Bearings - RB30 Main Bearings Standard Size 7M2394H-STD  $100
New NDC Bearings - RB20, RB30 Main Bearings MS-1203GP 1.0  $50
New King Bearings - RB26 Conrod Bearings CR6697-AM 0.25MM  $50
New Skyline R33 GTS, GTS-T Round Engine Mounts Pair   $100
New Crossfire Gaskets - Valve Stem Seals RB20, RB25 - 12 pack XVSS042  $20
New ProFlow Billet Fuel Rail - RB25 PFEFRKRB25BK  $100
New Raceworks Billet Fuel Rail - RB25 ALY-029  $100
New NGK Iridium IX Spark Plugs - 6 Pack BRK6EIX  $80
New NGK Spark Plug BCPR7ES  $5
New NGK Spark Plug BKR6ES-11  $5
New NGK Spark Plug - Laser Platinum PFR5G-11  $10
Aftermarket Replacement Parts:
New Skyline R33 GTS, GTS-T Brake Master Cylinder   $50
New Skyline R33, R34 Steering Rack Ends   $40
New Mongoose M20S Alarm System M20S  $100
New Genuine Philips Xenon D2R 85126C1 single bulb  $80
Used Parts:
Used R34 Climate Control Unit   $120
Used R34 Climate Control Unit with Ambient Temp   $150
Used R34 Double Din Conversion Kit with Clarion Head Unit   $200
Used R34 Skyline Altia/Nismo front bar grille badge   $80
Used R34 Center Console Drink Holder Divider   $10
Used R34 series 2 Steering wheel airbag with "S" badge - Postage unavailable due to explosive charge.   $50
Used R34 Center Console with Rear Cup holders   $80
Used R33 Center Console (shallow type)   $50
Used R33 & R34 (Except GTR) strut brace - GReddy    $80
Used R33 & R34 (Except GTR) strut brace with Brake Master Stopper - Nismo   $80
Used R33 & R34 (Except GTR) strut brace with Brake Master Stopper - Stainless Steel   $80
Used R34 GT, GT-T Electric A/C Condenser Thermo Fan   $150
Used R32 GTS-T/GT-R Coupe Headliner - $100
Used GReddy Oil Cooler Kit - $400
  • Like 2
Updated 10:54PM, 18/03/19
Genuine Nissan:
New Genuine Nissan Gearbox Fork shifter boot to suit pull type fork (R34 Turbo pull type gearbox and maybe GTR?) - $20
New Penrite Racing 10 10W-40 Full Synthetic Oil   $50 - 1 LEFT
Engine Parts:
New Rocker Cover gasket bolt seals - $20/pack
New ARP Clutch Bolts pack - $35
New Permaseal MLSR Nissan RB20, RB25  MG3042MLSR - $60
New Mongoose M20S Alarm System M20S  $100 SOLD
New Aerpro Nissan ISO radio plug harness - $20
Used Parts:
Used R33 & R34 (Except GTR) strut brace - GReddy    $80 SOLD
Used R33 & R34 (Except GTR) strut brace with Brake Master Stopper - Stainless Steel   $80  SOLD
Used Genuine R33 GT-R 400R dual aluminium blade spoiler - $700
Used Genuine Nismo Sport Manual pedals set - $200 (have the set, just not pictured yet)
Used Genuine Impul Manual Shifter knob - $100
Used Genuine Impul Auto Shifter knob - $100
Used Genuine Skyline R34 Altia/Nismo front bar grille badge - $50
Used other badges - $10 ea.
Used Nismo clutch slave cylinder to suit R34 GT-T pull type gearbox - $50
Used Genuine GReddy Profec B Spec II Boost Controller - $200
Used Genuine HKS Speed Limit Defencer - $100
Used Skyline R33 Ignition & door lock set for coupe - $100
Used Skyline R34 Genuine OEM Fog lights - $100
Used Skyline R32 GTS-T Genuine Fog light, left - $100
Used Skyline R33 Coupe Master Door Switch, 12 pin type (good condition) - $150
Used Skyline R34 GT-T Side mount intercooler SMIC vent OEM - $50
Used Skyline R33/R34 Fire extinguisher bracket, trimmed to suit aftermarket rails - $50
Used Skyline OEM Stock Side mount intercooler - $20
Used Turbosmart dual port BOV - $200
Used Skyline R34 GT/GT-T Coupe boot carpet - $50
Used Alpha Horns - $50
  • Like 1
  • 1 month later...
  • 2 months later...
  • 11 months later...
  • 9 months later...
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
