1998 Nissan Skyline R34 GT non turbo 4-door, Auto, 82,000 kms, White, $15,700 plus tyres and ORC's
what about that for a first car it looks mad R34 only like $18000 on the road
1998 Nissan Skyline R34 GT 2.5 litre non turbo 4-door sedan
Tiptronic automatic
81,980 kms
White
Dual airbags
ABS brakes
All power options and airconditioning
Central locking
Stock standard
Condition notes: Slight wear on steering wheel. Seat is a little dirty. Front bumper and LHR bumper / quarter panel are scuffed and may require some minor paintwork. Otherwise in excellent condition inside and out. High resolution pictures are available.
its with http://www.prestigemotorsport.com.au/au/st...sp?StockID=2343
I'd want to confirm that it can actually be complied before getting too ahead of yourself. Looks alright but is very cheap for that price...
Check out insurance too because many insurance companies won't differentiate between an NA and Turbo Skyline pricewise.
But would be a very nice ride.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
