Garrett Dash 5 aka 2860 turbos (HKS 2530)
Larger billet front wheel. The front compressor housing has been machined to fit the larger wheel.
RB26 ported exhaust manifolds
HPI dumps
GCG Internal Wastegates
All parts have been ceramic coated
Fantastic upgrade to your R32/33/34 GTR.
Come as pictured. Located in Moorabbin, VIC.
Have only been on the car for dyno time and then decided to go down a different route.
These turbos have the response of a dash 5 and power of a dash 10.
Everything is like new
Decided to paint engine bay
Engine was out my mechanic pushed me for a turbo kit and he gifted me it if it didn't make me happy with 600kw.
$4500 for the whole kit
https://www.sau.com.au/forums/topic/476647-parts/
  • 3 weeks later...
  • 3 weeks later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
