Well ladies, I have not been on the forum of late, my new job and new baby have meant I have virtually zero time on my hands any more.
The good news is, my R34 Vspec II is just about here, I expect if off the boat in about 1 week. Compliance is all t'ed up and I cant wait. Below are some pics of black beast.
Mods:
Pods, exhaust, HKS in car adjustable suspension, Dry carbon fibre bonnet and WEDS 18" wheels, additional computer module.
I have a PFC, boost kit and INJ on the way as well.
I want to do some other mods but that is another thread.
See out on the roads real soon. I might come on a cruse once I have her complied.
https://www.sau.com.au/forums/topic/47757-ozgtr97v-soon-to-be-ozgtr02v2/
  • Replies 56
I have access to a standard R34 GTR for the airbox, exhaust and a bonnet if needed. I will let everyone know how it all goes. The STD suspension is in the boot so no issues there.
Vspec II's replaced Vspec I's after March 2001.
Compliance will be between $5500 and $7000 depending on a lot of things.
Fatz,
She's a sick looking B!tch, cant wait to be behind the wheel. After almost 4 years with the white one, im really looking forward to drive something new and different. Do you think I will be hard to find on the road? Although there is a lot of R34's around today. Hopefully not to many Vspec II's with carbon bonnet and gold wheels!
I love the Apexi like HUD, see below. This was a nice supprise, will help a lot on track days, as will the bonnet, it will help keep the temp down once I get the KW up!
mesh,
No, I will probably go for the GTSS's after the GTRS experiance, they are not suited to what I need out of my car.
Fatz, Im waiting for a report back on my STD turbo's then we can talk the sphincter of the universe on the GTRS's.
2rismo,
The suspension is, HKS HiperMax II suspension, and you are right they are not in car adjustable, the car did have the Tien in car adjustable at one stage
2rismo,
Yikes... hold your kidneys!! Thats what I have in my GTR and holy bumpy batman!! :cheers:
Prank,
I think I might stay with the STD VSPECII suspension which has to be on the car for compliance anyway. I will wait and make that call once I get to drive the car, I will put a trade plate on it and take it for a spin with the HKS on it just to get a feel.
SW20 GT,
Im bringing it in myself and getting a complier to put the plate on it.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
