Hey Gents.
Well, I'm right to make some guides up.
I need to know numbers of people and front bars.
People in buy (front bar in brackets)
ME....................(Nissan Sports).......(DONE AND DUSTED)
ADZMAX............(Nissan Sports)......(DONE AND DUSTED)
RedBaron.........(Nissan Sports).......(DONE AND DUSTED)
ABOBOB...........(Nissan Sports).......(DONE AND DUSTED)
NJR 34GTT........(Nissan Sports).......(DONE AND DUSTED)
MUZ.................(Nissan Sports)........(DONE AND DUSTED)
ALL Nismo Bars are now supplied.
DAZ.................(Standard Bar)..........(DONE AND DUSTED)
NismoR34........(Standard Bar).........(DONE AND DUSTED)
GROUND RUN...(Standard Bar).........(DEPOSIT PAID)
CNBLOW..........(Standard Bar).........(DONE AND DUSTED)
COXY................(Standard Bar).........(DONE AND DUSTED)
Afro..................(C-West Front Bar)..(DONE AND DUSTED)
Eriktufa.............(Top Secret Bar).....(DONE AND DUSTED)
GTTR34............(URAS bar)...............(DONE AND DUSTED)
THAT'S ALL FOR NOW
PRICES ARE $65 as I didn't take into account the cost to get them bent.
BASS OUT
https://www.sau.com.au/forums/topic/47760-group-buy-r34-gt-t-radiator-guides/
  • Replies 175
You haven't put me down yet Bass!
Including me there are already 6 of us, prices should be geting better now :P
+ Abo Bob just needs a little convincing and he may join us too!
AboBOB
Come on.
It's cheap.
Good quality, fully routed, not turret punched. Bent up with love my me personally.
You couldn't ask for a better deal...........
Daz,
R34GTT
Anytime you guys want to meet up to measure your bars is good with me.
I work in Mitcham, and you could come after 5pm if you like.
ASAP would be good.
Daz,
R34GTT
ASAP would be good.
Early next week Peter, I'll ring u to arrange a time.
Cheers
:D
Hey Guys.
I've been called off on Business for the most part of next week.
I fly to Noumea on Sunday arvo and wont be back until Thursday.
I have sent drawings to my subbies who should e-mail the quote back to me early next week.
As soon as I know details I will let you all know.
BASS OUT
No probs, thanks for the update. :)
As for the Skylines Australia being engraved across the middle, I'd prefer mine left blank as I will be putting a few stickers on the top surface anyway.
Looking forward to getting mine! :(
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
