Calder park Sunday 24 November - READ NOW
WE NEED SOLID CONFIMRATIONS BY TOMMORROW AFTERNOON! 23rd October
Please, for this day to go ahead as a club event, and for you guys as members to get a discounted rate, trophies etc.. we really need 15 cars!
Please email me as soon as possible if you will be attending, eithrr as a spectator, or competitior.
Originally posted by inark
Im definate!
Guys from my work will be showing up too.
Zdenko - just got his R33 GTST
nothing - also just got his R33 GTST
bit of a primus skyline crew ;)
yeah I'll becoming, would be nice to get a timeslip before I fit new clutch and FMIC so I can see the diff aferwards :D
one question 400 metre in pretty much stock r33 (exhaust + airpod) will it hit speed limiter, what are some trap times of your guys cars for 1/4 mile?
Mid 14s...
hehe no u wont hit ur speed limiter...
i got 98 mph.
there isent much run off past the finish line so u gotta get on the brakes preety quick to be able to turn into the return lane!
Originally posted by Zdenko
mate mate mate mate mate mate... il hit my limitor in first gear cause my skylines an animal
hahaha
is there gonna be a burn out contest..
cause if there is i should have kept my como.. it done sick ree demos
hahaha ur such a di*k
ok so the list so far is...
inark
zdenko + 1
nothing +1
ex-static
INASNT
GTR31
Nismor31jet
?? add to the list ??
hahaha
trying to mock me zdenko? :D
but seriously what sort of 1/4 mile times need the speed limiter removed? when u start to run low 13's? also I've got a mate with a worked ss who wants to come with me is that cool?
oh I've got another stupid question :D
insurance are u covered by most policys while running the 1/4 at calder or are most void on the race track.. do u get some sort of cover provided by calder park?
might be stupid question but would hate for something unpredictable to happen...
Read your insurance policy, it will tell you that your car is not covered by insurance if you are racing (legal or otherwise)
All motorsport is undertaken at your own risk, and you will have to sign something that says that the owners and organisers of the event are in no way responsible for any damage done to your vehicle or yourself.
DRAGSAFE :D
now that i can post again...um, have you got me down on your list brendan? coz im still in if my gearbox hasnt sh!t itself by then yet! (does anyone no of a mini or a dato ute thats cheap so i can have some sort of a backup car so i can still get to work if my car poops itself?) i think i'll be the slowest car there but i dont care!
Originally posted by MZNISMO
ill be there to spectate !!! :uh-huh:
and as SDU head cheerleader!!! :)
will also be at heathcote sunday aswell
theres supposedly gonna be a big gtr meet
any of u guys going?
as long as u r there at calder in your mini skirt and pom poms doin a few cheers for us!
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
