Hi guys.
This is probably a very commonly covered topic, but today, i wanted to make a video to document the matter, and help those who may not know how to do this.
This tutorial will show you how to swap your Coil Packs in your s15 if you find that they are failing, or causing misfire.
*Background story - My car was idling fine and such, accel was fine in first 2 gears, but when in 3rd gear upwards, it would stutter and splutter, causing issues with acceleration under boost. I had a tip from some guys on the facebook group, and was told to check my ignition system. I had plans to change coils and plugs, but as i had a spare set of coils, though i would do them first. Changed coils, and did not have to touch my plugs, the issue is now gone. Please follow below for any assistance or instructions.
Please see my video for full instructional and visual.
For those who might not like watching videos, or tight on data, i will write the instructions below. Please follow closely.
If you have a similar issue or need to change your packs, you will need to make sure you have your car turned off.
Pop the bonnet, and you may see a silver plate, or a plate of sorts on top of your engine. If you don't have this, you can skip to the next step, if you have one, you will need to remove it with an alan key.
Once the silver plate is removed, you will need a 10ml socket to remove the 4 bolts holding the packs in.
When unplugging, please be extremely careful, as you can break the clips quite easily if you are too rough, as they are now very brittle after about 20 years of heat cycles.
When the plugs are removed from the packs, you can gently pull them up, you may need some force as they have grommets holding them in.
When the coils out, at this point, you can just replace it, or you can take it a step further, and change your spark plugs too. I recommend the ngk iridium plugs, they are supposed to last a long time, and are gapped perfectly if you are running a similar setup to me at 15 PSI.
If you decided to swap your plugs, make sure not to over tighten them when screwing them in.
Once they are in, you can follow the process to swap the coils, but backwards, when installing the new coils.
After you have done all this, turn on the car and see if the issue persists, take it for a cruise, and if all is well, congratulations, you have saved a trip to the mechanic!
Please feel free to leave me any feedback as it helps me make future content or tutorials!
All the best, see you next time!
Edited by zappandcrew
  • Like 1
    • Saw this video today from Adam LZ.    Long story short is he is claiming that the load from the engine fan once the fan clutch heats up(engaged) is increasing the getrag rattle(at idle) when you don't have a dual mass flywheel.  Before I go buying an electric fan setup .... Anyone heard of this ?    I must admit when my car is cold the getrag is pretty quiet and I do notice the rattle after it is all warmed up. I've always assumed this is due to the gearbox oil temp and tolerances of metal.
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
