SAU Dyno Day At Unique Autosports - Saturday August 21st
  • Replies 183
Echo thanks to John and his dyno operators / Unique / Turbosmart / Nick / Carlo / etc for running the day. My car was about where I expected it, just making sure it's still running good mixtures etc. When I have more time and money, R33 turbo + EBC :(
OK attendees from today....2 questions.
1) I only have names not forum nicks from today....so if you are an SAU club member and want Club Championships, please post here to let me know which car is yours.
2) I will be putting together a DVD from most of the runs for $5, who wants a copy?
Guest two.06l
two.06l = DIRTgarage gtr = dave
Hey Stacey, my list is probably out of date, are you guys SAU NSW club members?
My list of members from today....so far...is
Merli
Duncan
Kelly
Bman
Buster
Carlo
R33vit
Ash
CerealKiller
Neil
Blitz
Jimbo2000
BOO57A
GTR032
boosted Zed
please let me know if I've missed you :Oops:
updated points as follows:
Guest two.06l
Merli
Duncan
Kelly
Bman
Buster
Carlo
R33vit
Ash
CerealKiller
Neil
Blitz
BOO57A
GTR032
boosted Zed
yeah paid our money filled in the forms,asked prank to follow this up but have not heard any reply(think 2 months has passed).is anything else required??
OK, the DVD is ready to go
Sorry to those I missed, we ran out of tape (took over 3 hours of runs) but only got 20min of action! Each run is about 1.5min of action.
The DVD includes:
Chris/33 GTR/301
Wilch/33 GTST/167
Sean/na Supra/111.4
Haroon/S13 Silvia/159
Ash/33 GTST/173
John/32 GTST/151
Sam/33 GTST/198
Neil/33 GTST/160
Chris/240z/67
Dave/32 GTR/250
Jimbo/33 GTST/215
Scott/33 GTST/180
Bredan/33 GTST/328
Antonio/33 GTST/320
Gav/33 GTST/182
Stewart/M3 BMW/184
Kel/350z/157
Sadly we missed some of the big stars on the day including the 200b :D
Anyone who wants one, chuck $5 into:
Account: D & K Handley
BSB:082 401
Account: 48 324 1131
And don't forget your name so I know who paid. Then PM me your mailing address, its finished and ready to go out :(
Nick, I'll send a copy for UAS and Zoom, can you pm me ur address?
BSB:082 401
i think there is 1 too many numbers in that account number? netbank won't let me put it in...
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
