I’m looking to install my alarm into my 32 gtst and need more information about the ignition harness under the dash. I’m just wondering does anyone has a diagram / wiring table stating colours of each wire and it’s use. I can spend the time to identify them, it would just save me time if someone had already done it or knows where to source diagrams etc.
thanks ?
https://www.sau.com.au/forums/topic/477920-rb20det-ignition-harness/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
