Hey all, for sale is my Link G4+ GTRLink
Full specs can be found here: https://www.motorsportwiring.com.au/product-page/link-g4-plugin-nissan-r34-gtr-skyline
I had this professionally installed very shortly before taking the car off the road and stripping for a rotisserie respray.
Would put it back in, but the new build requires a Motec.
Unit is back in its original box and ready for its new owner.
Great computers and currently retailing for $1,900.
Selling for $900 and it’s literally the exact same thing.
I’m based in Canberra, but travel to Sydney at least once a month, so it can also be collected from a Castle Hill if preferred.
Thanks,
Andrew.
Hey all,
Just took out my Xtreme clutch from my R32. Love this clutch and it hasn’t had more than a couple thousand km’s put on it and car hasn’t been driven hard.
Beautiful to drive, feels very easy, but has heaps of bite when required.
Easily handled 330kw and is only being changed due to impending 1000+hp build.
$650.
I’m based in Canberra, but travel to Sydney monthly, so it can be collected from Castle Hill.
Hi all,
For sale are my 2 immaculate Garrett 2860R-5’s from my R32GTR. I’ve taken one apart to show the condition of the turbine (first pic).
https://gcg.com.au/petrol-performance/performance-3/turbochargers-garrett-t-gt-series/garrett-gt2860r-turbocharger-aka-gtr-5-s-detail
Turbos are only a few thousand km’s old (never tracked or stressed) and have been delivering an easy 330kw with a very nice power curve.
Only reason for sale is I’m going for a much bigger power build with a big single.
These are currently retailing for $3,200 new.
I also have custom titanium dump pipes and a full 3.5” exhaust, if you’re interested.
Available for pickup in Canberra or Castle Hill or can happily ship at buyers expense.
Thanks,
Andrew.
  • 1 month later...
  • 3 months later...
  • 1 month later...
hey Andrew, happy to buy those turbos off you if we can work out a price shipped to Canada...I had a -5 bite the dust. pm me if you are interested...
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
