Hey guys..
Just after some clues on what would be a good next upgrade.
I have a couple grand saved and was thinkin either between a Apexi SAFC or
FMIC or turbo back 3" hi-flow cat exhaust??
What you think I should do next to get the most out of my RB25DET
My mods at the moment are: Apexi Power Filter, 3" Cat back, GFB plummed bov, turbosmart T boost control.
https://www.sau.com.au/forums/topic/47878-whats-next/
I got the front strut brace, I'm thinking about taking care of suspension a little later down the line.
Im looking to pump more power out of the RB25 then to keep it on the ground I'll look at suspension.
Which one?
1. 3" turbo back exhaust ?
2. FMIC?
3. Apexi SAFC?
4. or any other ideas?
https://www.sau.com.au/forums/topic/47878-whats-next/#findComment-967186
id definately be going for a good suspension set-up to help with the launches and getting the power to the ground.
my 2c
What kind of suspension setup would you be looking at for for the runs?
And how much would I been looking for a decent setup?
I dont really wanna push more than $1k on suspension but if you guys could give me the rough idea on what I'd be looking for.
https://www.sau.com.au/forums/topic/47878-whats-next/#findComment-968436
a bit of topic but i was wondering performance wise if a hi flow cat peforms better than a gutted stock cat or vice versa. In regards to suspension, i would personally go lowered king springs accompanied by bistein shocks which would set you back no more than an 1k brand new as oppose to 2nd hand jap suspensions.
https://www.sau.com.au/forums/topic/47878-whats-next/#findComment-968474
Can anyone else point me in the direction of some springs and shocks?
I dont just want aftermarket suspension just for the f@rk of it..
I'd rather spend a lil more but no im getting the quality and right bang for my buck on the strip.. u know?!?
What does gutting the cat involve? Isn't that what you do to make dim sims :)
https://www.sau.com.au/forums/topic/47878-whats-next/#findComment-968797
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
