R34 and r33 pod intakes interchangeable?
Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush. -
It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
Did you even watch the video? Its not a steering wheel.
Are you sure the plugs are firing in the correct sequence at the correct time? Black or fuel soaked spark plugs are unlikely to want to fire properly. Fit a set of cheap coppers (like BCPR6ES) until you diagnose the problem. Are you sure the injectors are working properly, ie not flooding the cylinder?
Did you only check spark on cylinder 1? Give all cylinders a check for spark. So this swap you've done, the car had an RB25 in it before with this Z32, and you've just dropped another RB25 into it?
