Hi everyone,
needing some help!
I have searched and searched and searched and still coming up to no leads. I swear I brought the lemons of all lemons I have what seems like so many problems with my beauty that I don’t even know where to start! it’s a stock r34 rb25 neo auto
Firstly it’s not running the best, I have a few vacuum lines/hoses that aren’t connected (this way when purchase) I’ve tried to find out where they should be or even the purpose of them to ask around. I keep getting told one thing to another or just plain nothing. This is the first problem I am wanting to solve before moving on to the rest, I understand from some reading it may not be the main reason to it not running well but going through my list and eliminating one problem by one
Any help would be appreciated  ? would love to have it running and on the road before Christmas
https://www.sau.com.au/forums/topic/479116-vacuum-hoses-r34-rb25-neo/
I'd have to suggest that the hose that pokes off the top back of the TB is the trigger signal for the purge canister, and it goes via the solenoid valve down behind the rearmost of the two inlet manifold crossover pipes. It's a ported vacuum source that only works when the throttle is in a certain position.
The one on the driver's side of the plenum is the feed to the main vacuum system tank, from which all the other crap on the NA Neo is run (the variable intake stuff.)
GTSBoy is more than likely right. But don't worry he doesn't hate you, he just gets annoyed when someone says Skyline and N/A in the same sentence.
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
