On a car in queensland that comes standard with the same width wheels front and rear, for example my HCR32, is it roadworthy when upgrading wheels to have different widths front to rear.
ie. 18x7.5 F
18x8.5 R
instead of standard
16x6.5 F+R
i know that the tyres must be the same side to side. .just concerned with
1. how many inches wider than standard i can go and be roarworthy
2. if i can run wider on the rear than the front and stay roadworth
surely there are heaps of people here running non stanard rims that can shed some light. are r33's same width front and rear? what about r34's
thanks!
https://www.sau.com.au/forums/topic/47953-wheel-width-laws/
Extract from Qld Transport Vehicle Modification Guide
Full version of the guide can be dowloaded here
http://www.transport.qld.gov.au/qt/driver....dex/vehiclemods
Low Profile Tyres
It is common practice for manufacturers to fit low profile tyres
to high performance motor vehicles as standard equipment.
Low profile tyres (50, 60 or 65 series), replacing standard
profile tyres (70 series or above), are normally fitted in
combination with rims of larger than standard diameter to
maintain the correct overall diameter of the wheel.
A diagram of this concept appears below.
The rim diameter may be varied from the standard size
but the overall diameter of the tyre must not vary by more
than +15 mm or -26 mm.
These limits have been set for a number of reasons. Varying
the overall diameter of tyres affects ground clearance, centre
of gravity, brake effectiveness, steering geometry,
performance and speedometer accuracy.
Generally, to meet these limits, 60 series tyres are fitted to rims
with a diameter increase of 26 mm larger than standard and
50 series tyres are fitted to rims with a diameter 50 mm
larger than standard.
https://www.sau.com.au/forums/topic/47953-wheel-width-laws/#findComment-966859
General Conditions for Alternative Rims and Tyres
The rims and tyres must not protrude beyond the bodywork
of the vehicle, including flares, when viewed from above and
when the wheels are facing straight ahead. If the vehicle was
originally constructed with a portion of the wheel protruding,
the wheels must not protrude further than originally constructed.
The tyre to rim fitting and the tyre to rim combination must
be in accordance with the Tyre and Rim Standards Manual
published by the Tyre and Rim Association of Australia.
Reputable tyre retailers should have this information
and be able to advise on the correct combinations.
All rims fitted to an axle must be of the same diameter, width
and offset. They must not have a circumferential weld other
than that which attaches the outer rim to the centre.
All rims must have stud hole pitch circle diameters appropriate
to the hub. Wheel nut tapers must be appropriate to the wheel
and must engage the thread of the wheel studs for at least the
same length as the nuts provided by the vehicle manufacturer.
Slotted and elongated stud holes are not permitted.
The fitting of spacers between wheels and hubs, additional to
those provided by the vehicle manufacturer, is not permitted.
The tyre and rim must not foul wheel arches or suspension
components under any conditions. Steering limit stops should
not be adjusted to reduce the turning circle in order to allow
the fitting of the tyres and rims.
The tyres must have a tread depth of at least 1.5 mm on every
part of the tyre that touches the road and not have any
apparent defect that is likely to make the vehicle to which
they are fitted unsafe. It is not permitted to fit tyres that have
been treated by recutting or regrooving unless the tyre has
been marked by the original manufacturer as “suitable for
recutting or regrooving”.
https://www.sau.com.au/forums/topic/47953-wheel-width-laws/#findComment-966862
Tyres
The maximum tyre width must not be more than 1.3 times wider
than the vehicle manufacturer’s widest optional tyre. However, in
the case of off-road passenger vehicles fitted with front and rear
beam axles, the maximum tyre width must not be more than
1.5 times larger than the manufacturer’s widest optional tyre.
The nominal width of the narrowest tyre fitted to a vehicle must
not be less than 70 percent of the nominal width of the largest
tyre fitted and never less than the vehicle manufacturer’s
narrowest optional tyre as indicated on the manufacturer’s
tyre placard.
Hope this helps to educate all
https://www.sau.com.au/forums/topic/47953-wheel-width-laws/#findComment-966868
thanks gary.. i was looking on the net this morning tryin to find something like that.
by the sounds of all that i can run different widths front to rear.. but same widths per axle. i shoud be legal upgrading from
16x6.5 205 F+R
to
18x7.5 215/40/18
18x8.5 225/40/18
anyones experinces would help.
https://www.sau.com.au/forums/topic/47953-wheel-width-laws/#findComment-967338
