I'm parting ways with my R34 GTR Front end swap as I'm tieing the knot this year and gathering much required funds.
All parts are on Gumtree also.
Seibon Carbon Dmax bonnet unused $1200
Aerocatch carbon bonnet pins brand new $150
R34 GTR Bonnet hinges $50
R34 GTR bonnet catch brand new $100
R34 GTR bonnet catch assembly $50
R34 GTR/GTST bonnet stay $25
R34 Vspec Bumper w/splitter & Diffuser & nismo clear indicators $1000
R34 GTR Bumper reinforcement $200
R34 GTR reinforcement foam $50 brand new
R34 GTR top Bumper support bracket $50
R34 GTR bumper support wings $100 brand new
R34 GTR inner headlight brackets $50
https://www.sau.com.au/forums/topic/479562-r34-gtr-front-end-part-out-more/
Over the years I've collected and been hoarding genuine dealership brochures.
R32/R33/R34/R35
GTS GTST GTR GTS4 VSPEC NUR AUTECH
2 DOOR 4 DOOR.
NISMO
Optional Assesories
These go quick.
Edited by Stag love
  • Like 1
  • 10 months later...
Is bar still available if so pls WhatsApp 0450060060
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
