Howz it going guys,
I just brought my self an R33 and i live in Melbourne. My skyline has a BOV on it and i want to keep it on there, besides it sounding good it's also good for the turbo as we all know. Does anyone know if it's possible to keep the blow off valve on the car and keep it legal.
Thanx Matt.
https://www.sau.com.au/forums/topic/47963-blow-off-valves/
Howz it going guys,
Thanx Matt.
Only if its not venting to atmosphere and plumbed back in like the standard unit as far as I know. Then you loose the sound, so might as well have the stock unit and no problems.
https://www.sau.com.au/forums/topic/47963-blow-off-valves/#findComment-966899
Thanx guys so there is no way not even if i get an engineers certificate to say that the car requires one or that it is fitted as to his specification does anyone know if thats possible. i wanna try cover all areas to get around this one and im sure others have done this process and know the facts.
https://www.sau.com.au/forums/topic/47963-blow-off-valves/#findComment-967000
just quickly about BOV's, i have seen some BOV welded on the intake pipe. is that still illegal?
If its on the intake pipe.. before it hits the turbo, its not really "bad" air so to speak... at that point i would have though.. so it should technically be legal..
correct me if i am wrong guys.. still a noob :cheers:
https://www.sau.com.au/forums/topic/47963-blow-off-valves/#findComment-967009
You can't get a BOV engineered (unless it's a plumb back)
You can't get a certificate to say the car "needs one"... because it doesn't.
uh.... are you sure you aren't talking about air flow meters?
I don't know why anyone would put a BOV on the intake, it wouldn't do anything.
https://www.sau.com.au/forums/topic/47963-blow-off-valves/#findComment-967033
Is there any mechanical benefit on welding the BOV onto the intake as it's not getting rid of any excess air from the turbo or is it? And will it still cause a big and hard working turbo to stall on deceleration???
https://www.sau.com.au/forums/topic/47963-blow-off-valves/#findComment-967358
I have a HKS SSQV and the standard R34 BOV. I leave the HKS BOV off most of the time as it attracts too much attention and is just asking for a defect notice.
If the car comes factory fitted with a BOV then it is LEGAL. My car went through ADR37 compliance like every other import vehicle, and all factory fitted items are noted as compliant. The fact that the factory R34 BOV makes a wooshh sound makes no difference, it is a factory fitted item and my compliance plate says it passes as compliant so the cops or EPA cant do sh!t about it :)
https://www.sau.com.au/forums/topic/47963-blow-off-valves/#findComment-967458
Aftermarket BOV with plumb back will still make noise, well mine does any way (GReddy). From my experiance if you run high boost like mine does (1.5 bar), then an aftermarket one is needed (my stock one starts leaking for some reason).
My 2 cents worth.
https://www.sau.com.au/forums/topic/47963-blow-off-valves/#findComment-967597
the stock bov with a pod filter is pretty loud, just like a normal blow off valve, i dont see the need for an aftermarket bov unless you run a crapload of manifold pressure from heaps of boost aka 20psi ++
https://www.sau.com.au/forums/topic/47963-blow-off-valves/#findComment-967774
does the factory BOV make a venting to atmo sound??? I wasn't aware of that. Still haven't got my R34 so i don't know :rofl: never driven one either :D
https://www.sau.com.au/forums/topic/47963-blow-off-valves/#findComment-968123
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
