R31Nismoid:
ok so you are going on a chassis dyno to run the engine in.
are they going to do a full power run/tune? I understand you have a GT30 so are you going to take a freshyly rebuilt engine on a chassis dyno, do a few ramp ups to bed the rings in and then go all out 20psi 7500rpm power run and tune?
R31Nismoid:
I shall ask the question tomorrow of how it is all going to work.
But i beleive thats whats going to happen, once i drive out the roller door.
But yeah, ill find out in detail tomorrow
that'd be tops (Y)
then i can get more info and pass it onto my dyno guys.
Reckon you could find out the procedure for run in to etc and what it involves? They may keep it secret tho :S
I reckon i can indeed. I was getting told the plan of attack two weeks ago as i asked about running in and stuff and i was met with an odd look (i now know why)
I was told that he was sick of running in race motors as it took so damn long, so he didnt bother anymore.
After a 6 month hiding on the track, he would pull em apart and they'd look no different to a motor than spend hours & hours being "run-in"
So no long winded running in.
anyway, more to follow tomoz
Mine will be thrown on a car trailer and towed down to Shauns where he will run it in there.
I am curious as to how spot on the powerfc's base map is AFR' wise.
I will find out tomorrow I guess. :D Won't I Darren ;)
Son of a bi....:) Can i borrow your guineapig suit then? :)
haha i was met with that exact same look when i asked the same question...
mine should be due early next week and from what iv been told, by the time the car has been tuned up itll be ready to go without any "running in"
he (Ian at Amberly) said running in is an old term, when it comes to purpose built engines, all clearence and measure are done pretty much exact
who knows...but id belive what the builder says, especially if theres repuation to back his claims on engine building, not something someone wrote in a magazine
rings still need to be bed in properly. If they say something along the lines of what was siad above, id assume they are taking your car for a few hundred kms of run in driving....clearances done pretty much exact :bahaha: it would want to be, but rings still need to bed :)
Speaking to somebody yesterday about running in engines and was told similar to what R31nismoid and whistla said.
"Purpose built performance engines actually dont need as much running in as a mass produced ( falcon,commo) engine. Mass produced engines have less tension in the rings and therefore need a longer run in period to bed them properley. Whereas a performance engine will generally have a higher ring tension and bed a lot easier and faster. Car manufacturers have low tension rings as it creates less friction = less wear = better fuel economy."
But nonetheless rings still need to bed, no matter what engine they are in.
do u guys know how long a motor from Holden is "run in" fpr instance??
I do... and if you find out you'd see most others' point.
The fire em up (on mobil 1 sythetic) give a squirt check everything is in order (pressures etc etc) and whack em into the cars. They dont spend hours on an engine dyno or anything bedding in rigns blah blah. Not as if thier motors dont last many 100,000's of km's
Rings dont take hundreds of KM's to be bedded in.
I took put my stardard computer in my RB30DET to start it up. I drove it to the workshop and put it on the dyno. They told me it was running very lean, so i put my wolf in and they tuned it for right mixtures up to a 4000rpm rev limit while running it in. It is geting fully tuned after ive done 1000km, since ive just got to bed the rings in. Im glad i got the mixtures checked because i could have done damage. Will find out how much power its got by wednesday.
Yes Ash, I know what the manufacturers do. I also read somewhere that sometimes the engines are taken to redline to ensure everything is ok.
But you said : "do u guys know how long a motor from Holden is "run in" for instance??"
That is a misleading comment in the sense that a new car owner is not told there engine is ready for "normal" use. You are told you have to run it in and it is in the owners manual explaining the manufacturers recommendations on how they want you to do it.
A perfect example I would love to see is the GEN 3 engine. One driven hard from the outset and one ran in on the dyno as per Holdens recomendations. And then see which one has the better oil consumption.
I dont agree that a performance engine needs a long drawn out run in process but I also dont agree that it can be taken to the limit from the get go.
Whistla wrote: by the time the car has been tuned up itll be ready to go without any "running in"
Can you ask your builder approx. how many ks will it take for it to be "tuned up"
mine (same as mr whislta) will prob be done on dyno and thats it :)
Hi Ash, I think you will find that he will run her up on the dyno for initial break in and tune then advise you to come back after around 500 km's. In my experience he also knocked out a few degrees of total advance during the break in period.
yeah i think i'll take mine to get the mixtures checked out, this dyno time will also be loading it up a little helping bed the rings in... once the mixtures are ok, go driving for 500-1000km's then come back and say 'boost this mofo right up' :)
yeah i think i'll take mine to get the mixtures checked out, this dyno time will also be loading it up a little helping bed the rings in... once the mixtures are ok, go driving for 500-1000km's then come back and say 'boost this mofo right up' :P
exactly what i was told...and will be saying :D....500-1000kms is the critical bit, then let it fly :rofl:
    • If the gases flowing in those two tracts had the same properties, you could maybe use such broscience. But the exhaust has a different composition, different normal density, different actual density (because of different normal density, and mostly because of the massively higher temperature), and different viscosity (again because of much higher temperature). Consequently, all of the fluid dynamics parameters that matter, that you calculate from these inputs, such as the Reynolds number, friction factors (for wall friction) and so on, are all incomparable.
    • And we shall have to presume that Canada is the same?
    • In the US almost everything is E10. It can't exceed 10% by much or fuel systems have trouble adapting. At the same time because MTBE, MMT, and TEL are all banned they need as much ethanol in it as possible to boost octane.
    • I was mostly jesting. In my experience (and probably only my experience) the R34 GTT physical airbox space is actually too small to flow the amount of power it wanted. By sealing the box, I made it so it could only be fed by the ducts themselves. So you can seal it up and get nice cold air which IS good, but at a certain crossover point: More Hot Air > Less Cold Air I don't think you're at this point. In my case merely ducting the hot air intake with a very focused set of ducts counteracts the fact it's in a V8 engine bay. More cold air obviously best. The solution looks great.
    • Nah, the OEM CAI pipe is still installed behind the bumper, it is about 5" x 3" oval at the engine side, tapering down to a 3" pipe behind the bumper where it gets all the ambient air it needs Engine side of radiator support OEM intake pipe "oval hole" that is right in front of the filter My OEM NC1 CAI pipe: From NC2 onwards, below pic, they come slightly smaller at 2.75" diameter with corrugations and a resonance chamber to reduce intake noise, lucky for me my NC1 has the bigger noisy one, LOL   Basically, the "sealed" airbox will just get ambient air from a 3" pre filter intake tube that is the same size, 3" as the rest of the intake pipe post filter, and if a 3" intake isn't big enough to flow enough air for 150 killerwasps then there are other issues The whole intake is basically the same length as OEM, but it is now about 30% bigger from the airbox back through to the new intake plenum than OEM, and the intake plenum is port matched to the head And the intake is now about 30% bigger than my 2.5" exhaust, so the suck, squeeze, bang and blow black magic should be fine, well, to my uneducated understanding of fluid dynamics anyway Talking the the guys at MX5 Mania, it may even make a few more killerwasps as the intake isn't sucking hot air, especially off idle or when in slow traffic when it would be sucking hot air  As for the difference in IAT, I haven't logged IAT yet, as I don't currently have a OBD2 reader, but I will have a play with my thermal lazer thingie next time I take the car out to sèe how hot stuff gets under the bonnet near the intake filter prior to installing the air box, my "assumption is it has to be much better after the air box is in and sealed up compared to what it is now The aftermarket "performance" CAI elephant in the room: Aftermarket CAI intakes typically have the air filter tucked up behind the bumper, with a 2.5" intake tube (the OEM intake pipe is actually about 30% bigger than the fancy pants "aftermarket" version.....WTF), and you need to remove the bumper to service the filter, which is a PITA Like dis:
