This is an odd one. Let me start by saying I’ve used this forum for troubleshooting a lot of issues with 32 Gtr.
I actually bought the vehicle at a salvage yard and for the most part the rebuild has been going smooth. Intercooler, turbocharger inlet pipe, radiator and ac condenser have all been replaced. I did the 3 belts along with the tensioner and notice a squeal coming from p/s belt. Turns out the high pressure line was leaking at the O-ring, again this forum provided the answer. Replaced the O-ring and bought a new reservoir cap b/c the previous one had wires that snapped.
Turned the motor on to see everything in action and the belt still squealed and I the pump had a slow but consistent leak from behind the pulley where it meets the power steering pump.
Now it’s been about a week since I last worked on the car and noticed power steering fluid coming from the bottom of the radiator? I posted a pic for reference and I’m racking my brain trying to figure this one out. Maybe when the fluid was spraying inside the engine bay some of it got caught in the radiator? I also just put the car on jack stands because I have 3 droplets of coolant forming beneath the oil pan ?‍♂️. According to my forum research it can be the heater core or a few nuts located under the plenum. I appreciate any insight on this one or even reassurance that i’m not totally Burnt. Thank you for the read and help.
https://www.sau.com.au/forums/topic/479695-odd-issue/
Degrease everything. Make sure it is clean everywhere that has oil on it now. Run it for a bit, see where it gets wet.
Squealing belts/pulleys can be fixed by sandpapering the sheave faces. Don't do it while it's running! But the squealing may be because the pump has a problem. See how hard it is to turn, whether there's any wrong slop in it, etc.
https://www.sau.com.au/forums/topic/479695-odd-issue/#findComment-7924212
?? i will try the degreasing next. I thought it was a bad pump at first listen but when I sprayed the a/c belt With a tad bit if water the noise went away temporarily. Thanks for the suggestion
https://www.sau.com.au/forums/topic/479695-odd-issue/#findComment-7924247
Also I had added some ATF to my power steering and turned lock to lock. The steering isnt jittery any more and the squeal stopped when at idle but if I were to rev the motor it would let a scream out momentarily
https://www.sau.com.au/forums/topic/479695-odd-issue/#findComment-7924248
So I degreased the potential problem areas and found some interesting stuff. I knew my power steering pump seemed expired but Unfortunately I came across this sight. Any ideas?
You can see the coolant gathering under the oil pan. You can also see a droplet on one Of the Hicas lines in the front. Could it be a bad gasket? Bad water pump? Thanks everyone for your help
https://www.sau.com.au/forums/topic/479695-odd-issue/#findComment-7924469
Trace the wet up to where it comes from.
It is not unusual for the water pump to start to leak at the shaft seal, sometimes even at the gasket. These things need to be replaced every so often.
The PS pump could be leaking from it's shaft seal, from a hose connection or a body seal.
You know what fluids are leaking, you know what they are supposed to be kept inside. You just need to find out where they are getting out.
https://www.sau.com.au/forums/topic/479695-odd-issue/#findComment-7924479
Thanks GTS, I appreciate all your input. Im going to rip apart the front end and just do it right this time around.
https://www.sau.com.au/forums/topic/479695-odd-issue/#findComment-7924509
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
