Hi All,
Car : R33 GTST
One of the three bolts (the top one) that holds the AAC valve to the plenum has snapped. There is nothing sticking out for me to grab it and all the thread is in the plenum.
Is removing the top half of the plenum the only way for me to get to it for an extraction?
Thanks.
(I did search for this particular issue but only found threads about broken studs and bolts in other spots)
Edited by brentos
https://www.sau.com.au/forums/topic/479827-snapped-bolt-for-aac-to-plenum/
4 minutes ago, GTSBoy said:
If you can get a MIG welder onto it, you might be able to get it out in-situ. But otherwise, probably yes. Lid off.
I used to have a MIG welder but have since sold it. Looks like I will be taking the plenum off then
19 minutes ago, GTSBoy said:
Another option. How much space do you have back there? Enough for a pneumatic right angle drill? If you can drill it and you have enough room for the tap/ezy-out, then it's worth a shot.
I seem to have a little bit of space there once I push some of the wiring etc out of the way. I took a photo and circled the bolt in question. I might look into one of those right angle drill attachments off eBay.
The only thing is the broken bolt is not smooth and a bit jagged.
Thanks for your help
Edited by brentos
Taking off the plenum is hardly a huge job you would want to avoid at any cost.
How good are you at extracting broken bolts like that? If you have never done it before don't even try.
Take off the plenum and do it on a bench. Thank me later.
  • Like 1
I wouldn't say I am that confident in extracting broken bolts.
I have taken the plenum off before, was a bit of a pain getting to those bolts underneath, but if it has to be removed again then so be it.
One other thought, would a mobile thread doctor possibly have the right tools to get to it?
  • 3 weeks later...
Just wanted to give an update on this in case anyone else has a broken bolt in the same spot.
The Thread Doctor in Melbourne came out and got the broken bolt out. He did a fantastic job and at a fair price.
  • Like 1
As per GTSBoy, thnks for the update. Those guys are well worth thr money for the trouble they save!
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
