How hard is it to be done?
Basically me and a few other people seem to think that my car might already have aftermarket cams, as my car has a slight lumpy idle.
So i was told if i remove the rocker cover, i would be able to tell if the cams are standard or not.
Is this correct, and how hard is it to do?
Dean
https://www.sau.com.au/forums/topic/47991-removing-rocker-cover-on-33/
I havent dont it on an RB, but I have done it on another Nissan motor to check and lubricate after it had been sitting for a year. It was just a matter on undoing the bolts and levering it off? Just be careful not to damage the gasket.
Anything in the way obvisouly should be disconnected and reconnected afterward.
take off the items u usually need to whenm removing the sparke plugs...ie crossover pipe, and coil cover. The undo the 20 or so phillips head screws around the rocker covers...be careful not to shag the rubber sealing gasket, or buy a new one if your worried.
Not too hard, just remember what comes off when, then reverse the process to put back on...simple:)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
