All,
i have spun bearing on cylinder 2 and 3 and will be scrapping car if engine doesn’t last much longer so this is to get as much out of enginr before scrapping as car is not worth full proper rebuild
Now my question, spun bearing has melted on  the journal and part of it on rod inner bit( is there a term for it?)
i can’t get it off as it seems welded . I have seen some people used murantic acid but I want to know if there is any other way before i try that.
i think bearing is aluminume and bearing journal is steel
https://www.sau.com.au/forums/topic/480013-spun-bearing-melted/
Getting the bearing off the rod and crank is of no relevance, both will need to be measured and almost certainly machined before they could be re-used, let the machine shop sort it. BTW if it has spun that badly everything where oil goes needs to be disassembled and cleaned or replaced including any oil cooler and factory water/oil cooler.
If machining/rebuilding is out of budget throw them in the bin and put a second hand engine in.
the point is, getting the bearing remains out is irrelevant. The engine needs to be disassembled, measure and rebuilt or simply replaced.
if the bearing has spun enough to weld onto the journal, both surfaces are almost certainly f**ked and need machining. Potentially it is too badly damaged to even put oversize bearings in, but you can't tell without disassembling and measuring
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
