10 minutes ago, Na_skyline_r34 said:
There is alot on na 4 door r34s and their corresponding coilovers. But I am wondering if there is any other car that has compatible coilovers. What other car coilovers could I use?
Why?
8 minutes ago, Na_skyline_r34 said:
I have looked but can only find answers for the turbo option. I don't know what model this car is. Is it the gt? 25 gt?
Are you kidding? I have personally read at least a thousand time on here that the R34 NAs, with the exception of the GTV, all have the same lower damper mounts (eyelets) as the R33 GTST, and the R34 GT-T have the same type as GTRs (fork).
I'm just not very familiar with the different sub-modles. Thank you very much
Front suspension on GT and GTT are the same fittings but the rears are different. GTT has a lower fork fitting and GT has a lower eye fitting where it goes to the hubs. R34 GT fitment is same as an R33 GTST so I fitted a set of secondhand Apexi from an R33. Not sure about spring rates etc. but if you go for some adjustable coilovers then it doesn't matter and R33 should be cheaper anyway.
For brakes the mounting hole spacing on all of them is the same (including Z32, S14, S15 etc.). Some (e.g. R33 and R32) have 12mm threads on the front but R34s have 14mm holes. So to fit my R32 GTR calipers I used about 1cm of stainless steel sleeve (outer diameter 14mm, inner diameter 12mm, 1mm thick wall) in each bolt hole on the mounting bracket. The original 12mm bolt from the R32 goes through the sleeve in the R34 mounting bracket and into the caliper.
If you have R34 GTT calipers the threads will be 14mm already so no need for the sleeve. I'm pretty sure you need the matching disks as they are a bit bigger. I think the caliper mounting points are a bit longer to allow for this - but you'd better check on that. All of my stuff, calipers and disks were off a 32 GTR.
Rear calipers are all fitted straight up with the same bolts - no problems.
Some helpful info here about compatibility between models ... https://web.archive.org/web/20150912120446/http://nissans15.com/brakes.htm
This info was part of a private message from @DatsunBanana ... very good guy to talk to about NA r34’s and helped me alot
Edited by Dil-Dog
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
