Hey guys, first time poster, could really use some help,
Spent some time doing this setup on my mates 34, one major thing was to keep all the stock stuff functionable an to fit with the aftermarket parts, (merely wanted a clean engine bay)
Its come time to start it, but won't start....
I didn't use the stock TB, I put on the 88mm the plenum came with an wired up a raceworks TPS sensor,
I have spark, I have injector pulse, could the elimination of the stock throttle body stop it from starting?
Thanks in advance
https://www.sau.com.au/forums/topic/480386-r34-25detneo-wont-start/
Got fuel aswell.
Doesn't have traction control, but yeah running stock ecu harness etc, just aftermarket bolt ons,
Is nistune the only option?
Not really fussed about an engine light at the moment just want to get it running
Edited by -R34GT-
The standard ECU thinks that there should be a TCS/ABS ECU present. If there is not, there will be fault codes.
The TCS/ABS CU, if it is present, will be freaking out because you have lopped off its throttle motor and position sensor. There will also be ECU fault codes because of this.
Nistune is the only way to make a standard ECU work nicely under this level of abuse. The Neo ECU is fairly obsessive compulsive about a few things.
8 minutes ago, KiwiRS4T said:
How big is that turbo? What ECU are you planning to run it with?
You say you have no ignition light...is  the starter turning the engine?
Engine turns over an everything performs as it should (minus the deleted TB) just doesn't start.
Its a gt35/40, now decided to go aftermarket ecu an loom, only made this post to see if anyone had a possible way to get the car to run an drive as it was with the factory ecu.
45 minutes ago, Ben C34 said:
The car should run, unless you have done something weird.not well but should run. You sure you wired that  tps correctly
Thats what I would have thaught, should atleast start an run, an yeah I double checked the tps wiring, have the voltage aswell,
Only thing that isn't hooked up is the original TB
And that is not going to work anyway, that is a switch not a sensor
Try plugging in old tps and traction control throttle body and see what happens. Trying random piggy backs is not going to help you.
Also what's the status of the iac set up?  Did that also fall victim the plan of having a "clean engine bay"
I tried plugging the old throttle body back in before doing the ecu, an it didn't do anything, no noise no movements no starting,
The hks was only put in to try simply cause I was being told that removing the throttle body an its components will cause the ecu to freak out, think it was mentioned in an earlier post too,
An the Iac is still there an functionable
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
